1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Weird stream device behavior when using the IOC shell's exit function
From: Dirk Zimoch via Tech-talk <[email protected]>
To: <[email protected]>
Date: Wed, 6 Feb 2019 17:08:06 +0100
On 06.02.19 16:58, Dirk Zimoch via Tech-talk wrote:
I am not sure if scanning has stopped.  epicsExit is hung up trying to close the socket. The question is when that happens in the shutdown. The epicsAtExit call to register that exit function  is called when the drvAsynIPPort is created, which is before iocInit.  Does that mean it will be called before or after record scanning is stopped?
epicsAtExit calls the handlers in inverse order. Last installed is first called.
This probably does not answer the question. It depends on when in the shutdown process the epicsAtExit handlers are called. I am not sure. Probably via the C exit handler. That would be at the very end, i.e. when exit() is called or main() returns. Also somewhere at that time the C++ destructors are called. I don't know when this happens relative to stopping the scan threads...
Weird stream device behavior when using the IOC shell's exit function Abdalla Ahmad via Tech-talk
Re: Weird stream device behavior when using the IOC shell's exit function Dirk Zimoch via Tech-talk
RE: Weird stream device behavior when using the IOC shell's exit function Mark Rivers via Tech-talk
Prev: EPICS June 2019: Sessions and Workshops Ralph Lange via Tech-talk
Next: RE: Weird stream device behavior when using the IOC shell's exit function Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Weird stream device behavior when using the IOC shell's exit function Dirk Zimoch via Tech-talk
ANJ, 06 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
