Subject: |
ioc crash with ip module (synaps) TPG261 message too small=0 |
Heinz Junkes via Tech-talk <[email protected]> |
To: |
Date: |
Wed, 13 Feb 2019 18:35:23 +0100 |
Using epics7
asyn Release 4-34
ip Release 2-20 XXX, 2018
if there is no TPG261 connected to the serial port, the ioc chrashes with
2019/02/13 18:23:58.277 devTPG261::devTPG261Callback Val trARPES:HHG:ID message too small=0
is called in the st.cmd like
drvAsynIPPortConfigure("MOXA_9", "172.24.192.29:4009", 0, 0, 0)
asynSetTraceIOMask("MOXA_9", 0, 0x2)
asynSetTraceMask("MOXA_9", 0, 255)
dbLoadRecords("$(IP)/ipApp/Db/TPG261.db", "P=trARPES:, ADDR=1,TIMEOUT=5, GAUGE=HHG, PORT=MOXA_9")
Heinz
## EPICS R7.0.1.2-DEV
## EPICS Base built Oct 14 2018
2019/02/13 18:23:53.767 devTPG261::initCommon name=trARPES:HHG:SUNIT; command string=SET_UNIT command=3 address=1
2019/02/13 18:23:53.767 devTPG261::initCommon name=trARPES:HHG:ID; command string=GET_ID command=0 address=1
2019/02/13 18:23:53.767 devTPG261::initCommon name=trARPES:HHG:UNIT; command string=GET_UNIT command=2 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:PRES; command string=GET_PRESSURE command=1 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SP1V; command string=GET_SPVAL1 command=6 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SP2V; command string=GET_SPVAL2 command=9 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:START; command string=SET_SENSOR command=5 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SET1; command string=SET_SP1 command=8 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SET2; command string=SET_SP2 command=11 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:STATUS; command string=GET_SENSOR command=4 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SP1S; command string=GET_SPS1 command=7 address=1
2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SP2S; command string=GET_SPS2 command=10 address=1
|019/02/13 18:23:54.269 devTPG261::buildCommand trARPES:HHG:ID len=4 string=|TID
2019/02/13 18:23:54.269 MOXA_9 addr -1 queueRequest priority 0 not lockHolder
2019/02/13 18:23:54.269 asynManager::portThread port=MOXA_9 callback
2019/02/13 18:23:54.269 MOXA_9 set Eos 2
\r\n
2019/02/13 18:23:54.269 172.24.192.29:4009 write.
2019/02/13 18:23:54.270 172.24.192.29:4009 write 4
TID\r
2019/02/13 18:23:54.270 wrote 4 to 172.24.192.29:4009, return asynSuccess.
2019/02/13 18:23:54.270 MOXA_9 wrote
TID\r
]019/02/13 18:23:54.270 devTPG261::devTPG261Callback Cmd trARPES:HHG:ID nwrite=4, output=[TID
2019/02/13 18:23:54.270 172.24.192.29:4009 read.
2019/02/13 18:23:54.270 172.24.192.29:4009 read 15
\377\373\001\377\373\003\377\373\000\377\375\001\377\375\000
2019/02/13 18:23:54.271 MOXA_9 read 15 bytes eom=0
\377\373\001\377\373\003\377\373\000iocRun: All initialization complete
################################################# Create autosave monitor sets
2019/02/13 18:23:54.272 create_monitor_set("iocIOCINFRA_0.req", 5, "P=iocIOCINFRA:")
st.cmd line 64: Command create_monitor_set not found.
create_monitor_set("iocIOCINFRA_1.req", 30, "P=iocIOCINFRA:")
st.cmd line 65: Command create_monitor_set not found.
## Report Installed and Configured I/O-Hardware Information
dbior 0 1 > /epics/iocs/log/Database/iocIOCINFRA.dbior
dbhcr > /epics/iocs/log/Database/iocIOCINFRA.dbhcr
dbl > /epics/iocs/log/Database/iocIOCINFRA.dbl
## Start any sequence programs
#seq sncxxx,"user=epics"
|pics> 2019/02/13 18:23:55.768 devTPG261::buildCommand trARPES:HHG:PRES len=4 string=|PR1
2019/02/13 18:23:55.768 MOXA_9 addr -1 queueRequest priority 0 not lockHolder
2019/02/13 18:23:56.275 MOXA_9 read from low-level driver returned 1
2019/02/13 18:23:56.275 devTPG261::devTPG261Callback Cmd trARPES:HHG:ID nread=15, input=[������]
2019/02/13 18:23:56.275 172.24.192.29:4009 write.
2019/02/13 18:23:56.275 172.24.192.29:4009 write 1
\005
2019/02/13 18:23:56.275 wrote 1 to 172.24.192.29:4009, return asynSuccess.
2019/02/13 18:23:56.275 MOXA_9 wrote
\005
2019/02/13 18:23:56.275 devTPG261::devTPG261Callback Val trARPES:HHG:ID nwrite=1, output=[P]
2019/02/13 18:23:56.275 172.24.192.29:4009 read.
2019/02/13 18:23:58.277 MOXA_9 read from low-level driver returned 1
2019/02/13 18:23:58.277 devTPG261::devTPG261Callback Val trARPES:HHG:ID nread=0, input=[]
@@@ Received a sigChild for process 19516. The process was killed by signal 11
@@@ Current time: Wed Feb 13 18:23:58 2019
@@@ Child process is shutting down, auto restart is disabled
@@@ ^R or ^X restarts the child, ^Q quits the server
Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
Faradayweg 4-6 |
D - 14195 Berlin | E-Mail: [email protected]
smime.p7s
Description: S/MIME cryptographic signature
2D waveform records Sobhani, Bayan via Tech-talk
Data migration Steve Kinder - UKRI STFC via Tech-talk
<2019>
2025
2026
FW: 2D waveform records Mark Rivers via Tech-talk
Fwd: ioc crash with ip module (synaps) TPG261 message too small=0 Heinz Junkes via Tech-talk
<2019>
2025
2026
