I had sent this answer yesterday but forgot once again that I need to manually add tech-talk to the cc: now. Grrr.
Sent: Wednesday, February 13, 2019 11:33 AM
To: 'Sobhani, Bayan' <[email protected]>
Subject: RE: 2D waveform records
The EPICS database, records, and Channel Access handles 1-D arrays, not 2-D.
That being said the EPICS areaDetector software is commonly used with 2-D, 3-D and higher dimensional arrays. EPICS waveform records are used. The waveform record treats the array as 1-D, but there are other
records that describe the actual number of dimensions and dimension sizes of the array. The waveform record just needs to be big enough to hold the entire array.
Is it possible to have 2D waveform in EPICS? I have a waveform PV called ScanResults with type “DBR_DOUBLE[4]”. Would it be possible for it to have a type “DBR_DOUBLE[2][2]”? I notice the asynPortDriver::readFloat64Array function has a
field for nElements but does not seem to have a field for dimensions.
Alex
- 2D waveform records Sobhani, Bayan via Tech-talk
Re: 2D waveform records Johnson, Andrew N. via Tech-talk
Job openings at ITER Ralph Lange via Tech-talk
<2019>
2025
2026
ioc crash with ip module (synaps) TPG261 message too small=0 Heinz Junkes via Tech-talk
<2019>
2025
2026
ANJ, 14 Feb 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
