1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: ioc crash with ip module (synaps) TPG261 message too small=0
From: Heinz Junkes via Tech-talk <[email protected]>
Date: Thu, 14 Feb 2019 08:59:36 +0100
Hi Mark,
I had the same impression when I saw the code. But I thought, since it is part of the ip module and
probably used for many years with APS, I must have missed something.
I will try to fix the code and report back.
Heinz
> On 14. Feb 2019, at 00:56, Mark Rivers <[email protected]> wrote:
> Hi Heinz,
> It is crashing in the readSi function:
>     rtnSize = strlen(pPvt->recBuf);
>     switch (pPvt->command) {
>         case GetID:
>             cloc =strchr(pPvt->recBuf, ',');
>             if (pPvt->address == 1) {
>                 ploc = pPvt->recBuf;
>                 *cloc = 0;    CRASHING HERE
>                 strcpy(pvalue,ploc);
>             } else {
>                 ploc  = cloc+1;
>         break;
> There are so many things wrong with this code I don’t know where to start!
> devTPG261Callback is where the actual I/O to the device is done.
> It does store the return status of the I/O operation in pPvt->status, but then this status is never checked anywhere!
> The number of characters read is only in a local variable, not in pPvt, so the readSi function does not know that no characters were read.
> The read buffer pPvt->recBuf is not 0 filled before the I/O, so rtnSize above will not be zero if the read failed, which it should be.
> The code above does not check if strchr returned 0 into cloc, which it apparently did in your case, and hence it is dereferencing a null pointer, causing the crash.
> The code is pretty simple, and it would not be hard to make it much more robust.  Want to volunteer?
> Mark
> From: [email protected] <[email protected]> On Behalf Of Heinz Junkes via Tech-talk
> Sent: Wednesday, February 13, 2019 12:59 PM
> To: tech-talk <[email protected]>
> Subject: Fwd: ioc crash with ip module (synaps) TPG261 message too small=0
> From: Heinz Junkes <[email protected]>
> Date: 13. February 2019 at 19:57:28 CET
> Thank you MArk,
> as fast as always. Sorry for the delay on my side but it took me a while to get the dump read on modern ubuntu
> (Had to go via apport, just for record
>  sudo service apport start
>  sudo apt install apport-retrace
>  apport-unpack /var/crash/_opt_epics_FHI_IOCINFRA_bin_linux-x86_64_IOCINFRA.1000.crash crash
>  cd crash; gdb `cat ExecutablePath` CoreDump
> but as a result it shows:
> [New LWP 20486]
> [New LWP 20479]
> [New LWP 20492]
> [New LWP 20474]
> [New LWP 20496]
> [New LWP 20473]
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> Core was generated by `../../bin/linux-x86_64/IOCINFRA ./st.cmd'.
> Program terminated with signal SIGSEGV, Segmentation fault.
> #0  readSi (pr=0x16521c8) at ../devTPG261.c:484
> 484                     *cloc = 0;
> [Current thread is 1 (Thread 0x7fb4a975e700 (LWP 20477))]
> Heinz
> On 13. Feb 2019, at 18:48, Mark Rivers <[email protected]> wrote:
> Hi Heinz,
> I just looked at the code.  The relevant parts are these:
>    if (nread < 1 ) {
>        asynPrint(pasynUser, ASYN_TRACE_ERROR,
>                  "devTPG261::devTPG261Callback Cmd %s message too small=%d\n",
>                  pr->name, nread);
>        recGblSetSevr(pr, READ_ALARM, INVALID_ALARM);
>        goto finish;
>    /* Process the record. This will result in the readX or writeX routine
>       being called again, but with pact=1 */
> finish:
>    dbScanLock(pr);
>    (*prset->process)(pr);
>    dbScanUnlock(pr);
> I don’t see anything obvious wrong there.  Can you get a stack trace to see where it is actually crashing?
> Mark
> -----Original Message-----
> Sent: Wednesday, February 13, 2019 11:35 AM
> To: Tech-talk <[email protected]>
> Subject: ioc crash with ip module (synaps) TPG261 message too small=0
> Using epics7
> asyn Release 4-34
> ip Release 2-20 XXX, 2018
> if there is no TPG261 connected to the serial port, the ioc chrashes with
> 2019/02/13 18:23:58.277 devTPG261::devTPG261Callback Val trARPES:HHG:ID message too small=0
> is called in the st.cmd like
> drvAsynIPPortConfigure("MOXA_9", "172.24.192.29:4009", 0, 0, 0)
> asynSetTraceIOMask("MOXA_9", 0, 0x2)
> asynSetTraceMask("MOXA_9", 0, 255)
> dbLoadRecords("$(IP)/ipApp/Db/TPG261.db", "P=trARPES:, ADDR=1,TIMEOUT=5, GAUGE=HHG, PORT=MOXA_9")
> Heinz
> ## EPICS R7.0.1.2-DEV
> ## EPICS Base built Oct 14 2018
> 2019/02/13 18:23:53.767 devTPG261::initCommon name=trARPES:HHG:SUNIT; command string=SET_UNIT command=3 address=1
> 2019/02/13 18:23:53.767 devTPG261::initCommon name=trARPES:HHG:ID; command string=GET_ID command=0 address=1
> 2019/02/13 18:23:53.767 devTPG261::initCommon name=trARPES:HHG:UNIT; command string=GET_UNIT command=2 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:PRES; command string=GET_PRESSURE command=1 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SP1V; command string=GET_SPVAL1 command=6 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SP2V; command string=GET_SPVAL2 command=9 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:START; command string=SET_SENSOR command=5 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SET1; command string=SET_SP1 command=8 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SET2; command string=SET_SP2 command=11 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:STATUS; command string=GET_SENSOR command=4 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SP1S; command string=GET_SPS1 command=7 address=1
> 2019/02/13 18:23:53.768 devTPG261::initCommon name=trARPES:HHG:SP2S; command string=GET_SPS2 command=10 address=1
> |019/02/13 18:23:54.269 devTPG261::buildCommand trARPES:HHG:ID len=4 string=|TID
> 2019/02/13 18:23:54.269 MOXA_9 addr -1 queueRequest priority 0 not lockHolder
> 2019/02/13 18:23:54.269 asynManager::portThread port=MOXA_9 callback
> 2019/02/13 18:23:54.269 MOXA_9 set Eos 2
> \r\n
> 2019/02/13 18:23:54.269 172.24.192.29:4009 write.
> 2019/02/13 18:23:54.270 172.24.192.29:4009 write 4
> TID\r
> 2019/02/13 18:23:54.270 wrote 4 to 172.24.192.29:4009, return asynSuccess.
> 2019/02/13 18:23:54.270 MOXA_9 wrote
> TID\r
> ]019/02/13 18:23:54.270 devTPG261::devTPG261Callback Cmd trARPES:HHG:ID nwrite=4, output=[TID
> 2019/02/13 18:23:54.270 172.24.192.29:4009 read.
> 2019/02/13 18:23:54.270 172.24.192.29:4009 read 15
> \377\373\001\377\373\003\377\373\000\377\375\001\377\375\000
> 2019/02/13 18:23:54.271 MOXA_9 read 15 bytes eom=0
> \377\373\001\377\373\003\377\373\000iocRun: All initialization complete
> ################################################# Create autosave monitor sets
> 2019/02/13 18:23:54.272 create_monitor_set("iocIOCINFRA_0.req", 5, "P=iocIOCINFRA:")
> st.cmd line 64: Command create_monitor_set not found.
> create_monitor_set("iocIOCINFRA_1.req", 30, "P=iocIOCINFRA:")
> st.cmd line 65: Command create_monitor_set not found.
> ## Report Installed and Configured I/O-Hardware Information
> dbior 0 1 > /epics/iocs/log/Database/iocIOCINFRA.dbior
> dbhcr     > /epics/iocs/log/Database/iocIOCINFRA.dbhcr
> dbl       > /epics/iocs/log/Database/iocIOCINFRA.dbl
> ## Start any sequence programs
> #seq sncxxx,"user=epics"
> |pics> 2019/02/13 18:23:55.768 devTPG261::buildCommand trARPES:HHG:PRES len=4 string=|PR1
> 2019/02/13 18:23:55.768 MOXA_9 addr -1 queueRequest priority 0 not lockHolder
> 2019/02/13 18:23:56.275 MOXA_9 read from low-level driver returned 1
> 2019/02/13 18:23:56.275 devTPG261::devTPG261Callback Cmd trARPES:HHG:ID nread=15, input=[������]
> 2019/02/13 18:23:56.275 172.24.192.29:4009 write.
> 2019/02/13 18:23:56.275 172.24.192.29:4009 write 1
> \005
> 2019/02/13 18:23:56.275 wrote 1 to 172.24.192.29:4009, return asynSuccess.
> 2019/02/13 18:23:56.275 MOXA_9 wrote
> \005
> 2019/02/13 18:23:56.275 devTPG261::devTPG261Callback Val trARPES:HHG:ID nwrite=1, output=[P]
> 2019/02/13 18:23:56.275 172.24.192.29:4009 read.
> 2019/02/13 18:23:58.277 MOXA_9 read from low-level driver returned 1
> 2019/02/13 18:23:58.277 devTPG261::devTPG261Callback Val trARPES:HHG:ID nread=0, input=[]
> @@@ Received a sigChild for process 19516. The process was killed by signal 11
> @@@ Current time: Wed Feb 13 18:23:58 2019
> @@@ Child process is shutting down, auto restart is disabled
> @@@ ^R or ^X restarts the child, ^Q quits the server
> Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
> Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
> Faradayweg 4-6        |
> D - 14195 Berlin        | E-Mail:        [email protected]
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Fwd: ioc crash with ip module (synaps) TPG261 message too small=0 Heinz Junkes via Tech-talk
RE: ioc crash with ip module (synaps) TPG261 message too small=0 Mark Rivers via Tech-talk
Prev: RE: ioc crash with ip module (synaps) TPG261 message too small=0 Mark Rivers via Tech-talk
Next: How to detect AsynIPPort disconnect? Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Data migration Steve Kinder - UKRI STFC via Tech-talk
ANJ, 14 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
