On 2/18/19 11:11 PM, Di Wang via Tech-talk wrote:
> Hi everyone,
> I have some problems when listening to two EVR in one VME. I want to read EVR event respectively and storage them in two waveform record. So I used the method which described in this link
> https://epics.anl.gov/tech-talk/2008/msg00241.php
I'm not sure if it is relevant to this discussion, but It's worth noting
that this post concerns a different EPICS driver for the same Micro Research
Finland hardware. My mrfioc2 driver didn't exist in 2008.
As a matter of habit. Which versions of EPICS Base, devlib2, and mrfioc2 are you using?
Also, what hardware and OS are involved?
> But when I test two EVR, both test:evr1:Event-Wf and test:evr2:Event-Wf will receive the same event twice.
By this you mean that both EVR cards are cabled to the same EVG?
If so, I don't understand what you mean by 'event "19" is not
supposed to received by evr1'.
>For example, in test:evr1:Event-Wf, the event number is like this: event "38" is received twice and event "19" is not supposed to received by evr1. But when I monitored the value of test:evr1:EventCode and test:evr2:EventCode, their value is correct and received the event sequence which they should received. It is very weird.
Can you provide a more complete database? It is hard for me to judge how
test:evr1:Event-Wf work without seeing its definition.
> I do not know if there is some wrong with my waveform device support but since EventCode record can separate different EVR why Event-Wf record receives two EVR's event?
> ...*_38 36 37 2 1 35 32 33 184 181 180 19 15 38 36 37 2 1 35 32 33 184 181 180...
> _*
> EPICS base version is 3.15.5, IOC is compiled in Linux and run on VxWorks, mrfioc2-2.2.0, EVRs are EVR-230-RF
> mrmEvrSetupVME("tstevr1", 3, 0x08000000, 5, 0xc0)
> mrmEvrSetupVME("tstevr2", 5, 0x08040000, 7, 0xc1)
Can you also include the dbLoadRecords() lines?
- Two EVR in one VME Di Wang via Tech-talk
RE: Pro-Dex Oregon Micro Systems EPICS hardware support Mark Rivers via Tech-talk
print all information about a PV including units rachid ayad via Tech-talk
<2019>
2025
2026
Re: Two EVR in one VME Konrad, Martin via Tech-talk
<2019>
2025
2026
