Dear Zhefu,
I don't know it the monitor threshold within the archive engine works
the same as the ADEL field within EPICS records.
For EPICS PVs, to send everything even if there is no change, the ADEL
field should be '-1'. '0' means at least 1 bit in VAL has to change.
Hope this helps.
Best regards,
Florian
On 2/20/19 4:11 PM, lzf neu via Tech-talk wrote:
Dear Dr. Kay,
For special purposes, I intend to let the archive engine write real time data to database every monitor period (my period is 1.0s), irrespective of whether the real time data changed.
I tried to set the XML configuration file for a monitor with engine enforced value change threshold of 0.0 as follows:
<channel>
<name>NSV:P2</name>
<period>1.0</period>
<monitor>0.0</monitor></channel>
However, I faild. I have no idea how to achieve the goal. Any help will be appreciated and thanks in advance.
Zhefu
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
- Question about rdb channel archive lzf neu via Tech-talk
RE: print all information about a PV including units Mark Rivers via Tech-talk
Re: print all information about a PV including units Johnson, Andrew N. via Tech-talk
<2019>
2025
2026
GNU Screen or procServ on ARM? John Dobbins via Tech-talk
<2019>
2025
2026
