1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: epics-Keithley_648x, drvAsynKeithley648x
From: Heinz Junkes via Tech-talk <[email protected]>
Date: Wed, 6 Mar 2019 14:09:24 +0100
Hello, Mark,
thank you for your answers. Unfortunately it doesn't work that way either:
startup
drvAsynIPPortConfigure("MOXA_4", "172.24.192.29:4004", 0, 0, 0)
drvAsynKeithley648x("6485", "MOXA_4",0)
drvAsynKeithley648x::drvAsynKeithley6485 port MOXA_4 can't connect to asynCommon on Octet server 0 address 0.
asynSetTraceIOMask("MOXA_4", 0, 0x2)
asynSetTraceMask("MOXA_4", 0, 0x9)
dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, PORT=6485")
The driver is from https://github.com/dohnarms/epics-Keithley_648x
In the driver there seems to be a mismatch
/* Public interface forward references */
int drvAsynKeithley648x(const char* myport,const char* ioport, int ioaddr);
 * Define public interface methods
int drvAsynKeithley648x(const char *type, const char *myport,
                        const char *ioport, int ioaddr)
  int status = asynSuccess;
  Port* pport;
  //  int i;
  asynStandardInterfaces *pInterfaces;
  char inpBuf[BUFFER_SIZE];
  int eomReason;
  pport = (Port*)callocMustSucceed(1,sizeof(Port),"drvAsynKeithley6485”);
 * Register public methods
/* Initialization method definitions */
static const iocshArg arg0 = {"type",iocshArgString};
static const iocshArg arg1 = {"myport",iocshArgString};
static const iocshArg arg2 = {"ioport",iocshArgString};
static const iocshArg arg3 = {"ioaddr",iocshArgInt};
static const iocshArg* args[]= {&arg0,&arg1,&arg2,&arg3};
static const iocshFuncDef drvAsynKeithley648xFuncDef =
  {"drvAsynKeithley648x",4,args};
static void drvAsynKeithley648xCallFunc(const iocshArgBuf* args)
  drvAsynKeithley648x(args[0].sval,args[1].sval,args[2].sval,args[3].ival);
/* Registration method */
static void drvAsynKeithley648xRegister(void)
  static int firstTime = 1;
  if( firstTime )
      firstTime = 0;
      iocshRegister( &drvAsynKeithley648xFuncDef,drvAsynKeithley648xCallFunc );
epicsExportRegistrar( drvAsynKeithley648xRegister );
That is why I have given four arguments in the st.cmd.
Danke,
Heinz
> On 6. Mar 2019, at 13:51, Mark Rivers <[email protected]> wrote:
> My comments are:
> Your original message says that drvAsynKeithley6845 take 3 arguments.  Your actual commands call drvAsynKeithey648x with 4 arguments.  Why the difference?  Does 648x take an initial argument with the exact model number, or is that the name of the new port?
> I don't see the need for the asynOctetConnect line.
> Maybe this will work:
> dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, "6845")
> I deleted the asynOctetConnect, deleted the 3 argument to drvKeithley648x, and changed the port passed in dbLoadRecords.
> Is this driver code on Github or somewhere else we can look at it?
> Mark
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: epics-Keithley_648x, drvAsynKeithley648x Mark Rivers via Tech-talk
epics-Keithley_648x, drvAsynKeithley648x Heinz Junkes via Tech-talk
Prev: Re: epics-Keithley_648x, drvAsynKeithley648x Mark Rivers via Tech-talk
Next: Re: epics-Keithley_648x, drvAsynKeithley648x Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 06 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
