1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Multi-axis sequenced move using asynMotor pseudo axis
From: Maren Purves via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 7 Mar 2019 10:28:08 -1000
Hi all,
I have done something similar (9 motors) with a rather long and involved gensub/asub. That's another possibility.
Maren Purves
East Asian Observatory
On 3/7/19 07:08, Engbretson, Mark S. via Tech-talk wrote:
Can you post the entire solution with the other sseq records?  This is actually a rather burning demand for a lot of people who have worries about collisions or are dealing with a mix of very fast and very slow motors.
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Pearson, Matthew R. via Tech-talk
Sent: Thursday, March 7, 2019 11:03 AM
To: David Vine <[email protected]>
Cc: [email protected]
Hi David,
I do similar things using the sseq record, and calcout records to do checks that everything got to where it should do before progressing the sseq.
If you set WAITN to be ‘Wait’ for each sseq output, and use a CA link, it will do a put_callback and wait for the motor to finish moving.
I’ve pasted one example below, complete with comments explaining what each record does. It uses other sseq records to actually do the home for each motor, which I’ve not included, but it does show the high level sequencing, as well as the safety checks at each step.
Cheers,
Matt
# /// Home the optics motors in the correct order.
# /// 1) Home DOY.
# /// 2) Move DOY to -240. This is sufficiently 'out' to safely home DOR and DOX.
# /// 3) Check DOY is OK and at safe position # /// 4) Home DOR and DOX together.
# /// 5) Check DOR is OK and at safe position # /// 6) Check DOX is OK and at safe position # /// 7) Move DOY back to what it was originally # /// record(sseq, "$(S):Mot:DO:Home") {
   field(WAIT1, "Wait")
   field(WAIT2, "Wait")
   field(WAIT3, "Wait")
   field(WAIT4, "Wait")
   field(WAIT5, "Wait")
   field(WAIT6, "Wait")
   field(WAIT7, "Wait")
   field(WAIT8, "Wait")
   field(DLY1, "0.0")
   field(DOL1, "1")
   field(LNK1, "$(S):Mot:DO:HomeStatus PP")
   field(DLY2, "1.0")
   field(DOL2, "1")
   field(LNK2, "$(S):Mot:DOY:HomeToLowLimit.PROC CA")
   field(DLY3, "1.0")
   field(DOL3, "-240.0")
   field(LNK3, "$(S):Mot:DOY CA")
   field(DLY4, "1.0")
   field(DOL4, "1")
   field(LNK4, "$(S):Mot:DOY:Home:Check.PROC CA")
   field(DLY5, "1.0")
   field(DOL5, "1")
   field(LNK5, "$(S):Mot:DO:HomeDORAndDOX.PROC CA")
   field(DLY6, "1.0")
   field(DOL6, "1")
   field(LNK6, "$(S):Mot:DOR:Home:Check.PROC CA")
   field(DLY7, "1.0")
   field(DOL7, "1")
   field(LNK7, "$(S):Mot:DOX:Home:Check.PROC CA")
   field(DLY8, "1.0")
   field(DOL8, "1")
   field(LNK8, "$(S):Mot:DOY:HomeMBMoveManDef.PROC CA")
   field(FLNK, "$(S):Mot:DO:Home:Cleanup") } record(seq, "$(S):Mot:DO:HomeDORAndDOX") {
   field(DLY1, "0.0")
   field(DOL1, "1")
   field(LNK1, "$(S):Mot:DOR:HomeToGalilHome.PROC PP")
   field(DLY2, "1.0")
   field(DOL2, "1")
   field(LNK2, "$(S):Mot:DOX:HomeToLowLimit.PROC PP") }
record(seq, "$(S):Mot:DO:Home:Cleanup") {
   field(DLY1, "0.0")
   field(DOL1, "0")
   field(LNK1, "$(S):Mot:DO:HomeStatus PP") }
# /// Homing status flag (for OPI feedback) # /// record(mbbo, "$(S):Mot:DO:HomeStatus") {
    field(VAL,  "0")
    field(PINI, "YES")
    field(ZRST, "Idle")
    field(ONST, "Running")
    field(ZRSV, "NO_ALARM")
    field(ONSV, "NO_ALARM")
    info(archive, "Monitor, 00:00:01, VAL")
# /// Check homing worked for DOY and it's at a safe position # /// record(calcout, "$(S):Mot:DOY:Home:Check") {
   field(INPA, "$(S):Mot:DOY:HomeToLowLimit:Status")
   field(INPB, "$(S):Mot:DOY:StatusOPI")
   field(INPC, "$(S):Mot:DOY.RBV")
   field(CALC, "(A!=0)||(B!=0)||(C>-100.0)")
   field(OOPT, "When Non-zero")
   field(DOPT, "Use CALC")
   field(OUT, "$(S):Mot:DO:Home.ABORT PP") }
# /// Check homing worked for DOR and it's at a safe position # /// record(calcout, "$(S):Mot:DOR:Home:Check") {
   field(INPA, "$(S):Mot:DOR:HomeToGalilHome:Status")
   field(INPB, "$(S):Mot:DOR:HomeBit")
   field(INPC, "$(S):Mot:DOR:StatusOPI")
   field(INPD, "$(S):Mot:DOR.RBV")
   field(CALC, "(A!=0)||(B!=1)||(C!=0)||(D<-1)||(D>1)")
# /// Check homing worked for DOX and it's at a safe position # /// record(calcout, "$(S):Mot:DOX:Home:Check") {
   field(INPA, "$(S):Mot:DOX:HomeToLowLimit:Status")
   field(INPB, "$(S):Mot:DOX:StatusOPI")
   field(INPC, "$(S):Mot:DOX.RBV")
   field(CALC, "(A!=0)||(B!=0)||(C<-1)||(C>1)")
# /// Abort the above home sequence
record(dfanout, "$(S):Mot:DO:HomeAbort") {
   field(DOL, "1")
   field(OUTA, "$(S):Mot:DO:Home.ABORT PP")
   field(OUTB, "$(S):Mot:DOY:Home:Abort.PROC PP")
   field(OUTC, "$(S):Mot:DOX:Home:Abort.PROC PP")
   field(OUTD, "$(S):Mot:DOR:Home:Abort.PROC PP")
   field(OUTE, "$(S):Mot:DOY.STOP PP")
   field(OUTF, "$(S):Mot:DOX.STOP PP")
   field(OUTG, "$(S):Mot:DOR.STOP PP")
Data Acquisition and Controls Engineer
Spallation Neutron Source
Oak Ridge National Lab
On Mar 7, 2019, at 11:49 AM, David Vine via Tech-talk <[email protected]> wrote:
Hi all,
I'm looking for the cleanest way to implement a sequence of moves of between different physical axes but hide it from the user so it appears as just a single pseudo motor axis.
For example, I want to home axis A but to avoid a collision I need to move axes XYZ to a particular location first, then home A, and then move XYZ back to their original position at the end of the homing procedure. And that sequence should occur just clicking the home PV of A.
I would like to set up a pseudo motor driver using an asynMotor driver and implement the logic there. Is it possible to do channel access calls from within an asynMotor driver? I couldn't find any examples. The physical axes are connected across three galil controllers.
Implementing the logic within an SNL program would work but it seemed simpler to do it within the motor driver.
David
Best regards,
David Vine
(925) 326 7503
[email protected]
Multi-axis sequenced move using asynMotor pseudo axis David Vine via Tech-talk
Re: Multi-axis sequenced move using asynMotor pseudo axis Pearson, Matthew R. via Tech-talk
RE: Multi-axis sequenced move using asynMotor pseudo axis Engbretson, Mark S. via Tech-talk
Prev: RE: Multi-axis sequenced move using asynMotor pseudo axis Engbretson, Mark S. via Tech-talk
Next: Re: Multi-axis sequenced move using asynMotor pseudo axis Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 08 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
