Thanks Matthew and Kevin for your input, much appreciated.
I find the database implementation difficult to read and maintain. The SNL is more readable but there's a lot of boilerplate in setting up the states and connecting to PVs.
Implementing the logic from within asynMotor has the following advantages: - readable and commented code,
- the motor record has many of the PVs that I would need to connect to and monitor with SNL already,
- i don't need to define states and all the overhead that goes with it because the axis::move and axis::home can implement all the logic
I don't know if it makes sense but if asyn could implement an asynChannelAccessPort I think it would simplify this problem a lot. David,
I find SNL programs to be cleaner than pure database implementations for
situations like this. The SNL program might be more work initially, but
it is often easier to maintain, especially if the sequenced move
procedure needs to become more complicated in the future. Breaking the
implementation into well-defined states makes it easier for others to
understand, troubleshoot, and modify the code.
Kevin
On 3/7/19 10:49 AM, David Vine via Tech-talk wrote:
> Hi all,
> I'm looking for the cleanest way to implement a sequence of moves of
> between different physical axes but hide it from the user so it appears
> as just a single pseudo motor axis.
> For example, I want to home axis A but to avoid a collision I need to
> move axes XYZ to a particular location first, then home A, and then move
> XYZ back to their original position at the end of the homing procedure.
> And that sequence should occur just clicking the home PV of A.
> I would like to set up a pseudo motor driver using an asynMotor driver
> and implement the logic there. Is it possible to do channel access calls
> from within an asynMotor driver? I couldn't find any examples. The
> physical axes are connected across three galil controllers.
> Implementing the logic within an SNL program would work but it seemed
> simpler to do it within the motor driver.
> Thanks,
> David
> Best regards,
> David Vine
> (925) 326 7503
> [email protected] <mailto:[email protected]>
> 5750 Imhoff Drive, Suite I | Concord, CA 94520 | USA
> <https://maps.google.com/?q=5750+Imhoff+Drive,+Suite+I%C2%A0+%7C%C2%A0+Concord,+CA+94520%C2%A0+%7C%C2%A0+USA&entry=gmail&source=g>
> http://www.Sigray.com <http://www.sigray.com/>
> This e-mail and any attachments are provided for the sole use of the
> intended recipient(s), and may contain information that is confidential,
> privileged, proprietary or otherwise protected by law. If you are not
> the intended recipient of this message, you are not authorized to read,
> print, retain, copy, forward or otherwise disseminate this message or
> any part of it. If you have received this e-mail in error, please notify
> the sender immediately by reply e-mail and delete the original message
> from your mail system. Thank you.
-- Best regards, David Vine (925) 326 7503
http://www.Sigray.com This e-mail and any attachments are provided for the sole use of the intended recipient(s), and may contain information that is confidential, privileged, proprietary or otherwise protected by law. If you are not the intended recipient of this message, you are not authorized to read, print, retain, copy, forward or otherwise disseminate this message or any part of it. If you have received this e-mail in error, please notify the sender immediately by reply e-mail and delete the original message from your mail system. Thank you.
Description: PNG image
- Re: Multi-axis sequenced move using asynMotor pseudo axis Pearson, Matthew R. via Tech-talk
- Multi-axis sequenced move using asynMotor pseudo axis David Vine via Tech-talk
- Re: Multi-axis sequenced move using asynMotor pseudo axis Peterson, Kevin M. via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
