1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Change/Sync General Time Providers
Date: Wed, 20 Mar 2019 14:52:12 +0000
Hello Tech-Talk,
We have two IOCs, both mv2700s running EPICS r314123j0 that have OS Clock times in the future. Our NTP time is correct and it is set to a higher priority but is not syncing with the OS time. Is there a way to force synchronization of the two time providers at run-time? Or is there a way to forcibly set the current general time provider at run-time? Rebooting is an option, but I'm checking to see if there is a run-time solution. I've left some additional information below.
IOC command line:
#####generalTimeReport#####
vxwrks@ioc -> generalTimeReport 5
Backwards time errors prevented 315503 times.
Current Time Providers:
    "NTP", priority = 100
Current Time is 2019-03-20 10:11:35.092046.
    "OS Clock", priority = 999
Current Time is 2064-12-01 07:21:34.754838.
Event Time Providers:
No Providers registered.
value = 0 = 0x0
#####NTPTime_Report#####
vxwrks@ioc ->  NTPTime_Report 2
NTP driver is synchronized with server
Syncronization interval = 60.0 seconds
Last synchronized at 2019-03-20 10:02:34.116603
OS tick rate = 60 Hz (nominal)
Measured tick rate = 59.997 Hz
NTP Server = XXX.XX.XXX.XX
value = 0 = 0x0
#####ClockTime_Report#####
vxwrks@ioc -> ClockTime_Report 2
OS Clock synchronization thread not running.
value = 0 = 0x0
PV Status:
$(ioc):GTIM_CUR_SRC = OS Clock (***Is NTP on our functional IOCs***)
$(ioc):GTIM_HI_SRC = NTP
This is a strange one that seems to have come up before: https://epics.anl.gov/tech-talk/2017/msg01846.php
Any advice or suggestions would be much appreciated.
Thanks for your help,
Kyle
Re: Change/Sync General Time Providers Johnson, Andrew N. via Tech-talk
Prev: Re: R3.15.6 calc string doesn't accept LA, LB, LC, etc...? Mooney, Tim M. via Tech-talk
Next: Re: Inter-module dependency between stream and calc Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Change/Sync General Time Providers Johnson, Andrew N. via Tech-talk
ANJ, 20 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
