Hi Kyle,
On 3/20/19 9:52 AM, Kyle Hesse via Tech-talk wrote:
We have two IOCs, both mv2700s running EPICS r314123j0 that have OS Clock times in the future. Our NTP time is correct and it is set to a higher priority but is not syncing
with the OS time. Is there a way to force synchronization of the two time providers at run-time? Or is there a way to forcibly set the current general time provider at run-time? Rebooting is an option, but I'm checking to see if there is a run-time solution.
I've left some additional information below.
Unfortunately back in 3.14.12.3 the generalTime code had a forwards-only ratchet in its time synchronization routine, so if your OS clock runs fast it could never adjust it backwards with time from a higher priority NTP provider, which is obviously a problem.
The fix for that particular bug landed 2¼ years ago in 3.14.12.6. I can't promise that an upgrade will completely fix your problem, but if your CPU's tick timer runs fast you're always going to have issues with it until you do upgrade.
In your case though your IOC isn't currently running the OS clock synchronization thread for some reason — did someone give it a "ClockTime_Shutdown" command? There is no way to restart that thread by hand so you'll have to reboot the IOC anyway, but you might
want to investigate why it got stopped if you don't already know.
HTH,
- Andrew
IOC command line:
#####generalTimeReport#####
vxwrks@ioc -> generalTimeReport 5
Backwards time errors prevented 315503 times.
Current Time Providers:
"NTP", priority = 100
Current Time is 2019-03-20 10:11:35.092046.
"OS Clock", priority = 999
Current Time is 2064-12-01 07:21:34.754838.
Event Time Providers:
No Providers registered.
value = 0 = 0x0
#####NTPTime_Report#####
vxwrks@ioc -> NTPTime_Report 2
NTP driver is synchronized with server
Syncronization interval = 60.0 seconds
Last synchronized at 2019-03-20 10:02:34.116603
OS tick rate = 60 Hz (nominal)
Measured tick rate = 59.997 Hz
NTP Server = XXX.XX.XXX.XX
value = 0 = 0x0
#####ClockTime_Report#####
vxwrks@ioc -> ClockTime_Report 2
OS Clock synchronization thread not running.
value = 0 = 0x0
PV Status:
$(ioc):GTIM_CUR_SRC = OS Clock (***Is NTP on our functional IOCs***)
Any advice or suggestions would be much appreciated.
Thanks for your help,
Kyle
- Re: Change/Sync General Time Providers Kyle Hesse via Tech-talk
- Change/Sync General Time Providers Kyle Hesse via Tech-talk
Interns Needed? Gedare Bloom via Tech-talk
about Newport AG-UC module 최윤석 via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 21 Mar 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
