1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: EPICS Base 3.15 release notes epicsVersion.h macro snippet issues
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 1 Apr 2019 14:35:20 -0500
Hello, all.
At
  https://epics.anl.gov/base/R3-15/6-docs/RELEASE_NOTES.html
under
  Changes made between 3.14.x and 3.15.0.1
in the
  Changes to epicsVersion.h
section, it says
  A new pair of macros has been added to make version number comparisons
  easier. Code that will not work with a version of Base before 3.15.0
  can now be written like this to prevent it from compiling:
  #if defined(VERSION_INT) && EPICS_VERSION_INT < VERSION_INT(3,15,0,0)
  #  error EPICS Base R3.15.0 or later is required
  #endif
That has two problems, at least on macOS Mojave with Clang 10.0.1:
1. The function-like macro VERSION_INT can't portably be used later on
   in the same expression as the check for whether it's defined when
   it's not defined.
   For example, when compiling foo.c with the above preprocessor snippet
   against EPICS Base 3.14.12.8, Clang errors out with:
     ../foo.c:37:49: error: function-like macro 'VERSION_INT' is not defined
     1 error generated.
   A portable fix would be to check whether VERSION_INT is defined on
   its own:
     #  if EPICS_VERSION_INT < VERSION_INT(3,15,0,0)
     #  endif
     #endif
2. The logic of the macro snippet is wrong.  For example, when compiling
   against EPICS Base 3.14.x, the error (i.e., "EPICS Base R3.15.0
   or later is required") is *not* generated.  This is because the
   VERSION_INT function-like macro is not defined in EPICS Base 3.14.x.
Lewis
Re: EPICS Base 3.15 release notes epicsVersion.h macro snippet issues Michael Davidsaver via Tech-talk
Prev: EPICS Controls Engineering Job Opportunity - Full-Time, Direct Role Alexander Gorinsky via Tech-talk
Next: Re: EPICS Base 3.15 release notes epicsVersion.h macro snippet issues Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 01 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
