1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: EPICS 7 incompatibility in errMdef.h
From: Dirk Zimoch via Tech-talk <[email protected]>
To: EPICS <[email protected]>
Date: Tue, 2 Apr 2019 12:18:59 +0200
Hi folks,
Today while compiling a driver for EPICS 7 I found an incompatibility.
The function definition errSymbolAdd() (and others) have disappeared from errMdef.h. Thus when compiling a driver including errMdef.h and using errSymbolAdd(), I get a compiler warning because of the missing function prototype.
The prototypes are now in the new header file errSymTbl.h. But simply including the new file instead is no good solution, because then the driver does not compile with older EPICS versions any more.
Instead I have use compiler branches based on EPICS versions. That is a bit inconvenient.
What is the policy about backward compatibility in EPICS 7? Should we expect more compatibility breaking changes in the future in an attempt to "move forwards" or will EPICS 7 aim to stay backward compatible for 3rd party code like drivers?
Dirk
Prev: RE: Problem with NSLS2 Debian repository? Mark Rivers via Tech-talk
Next: PvData , PvAccess, Confusion with different hardware architectures Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with NSLS2 Debian repository? Flaks, Leonid via Tech-talk
ANJ, 02 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
