1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with NSLS2 Debian repository?
From: "Flaks, Leonid via Tech-talk" <[email protected]>
To: "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Cc: "tech-talk \([email protected]\)" <[email protected]>
Date: Thu, 2 May 2019 15:08:50 +0000
Thank you everybody for pointing out the issue.
I submitter request to our ITD.
Leon
On 5/2/19, 10:00 AM, "Konrad, Martin" <[email protected]> wrote:
    Hi Leon,
    > This does look a bit tricky.  On our systems (RHEL7), the certificate
    > is trusted by firefox, but not by curl.
    A quick check revealed that BNL's web server isn't configured correctly.
    It is providing it's own certificate but not the chain of certificates
    up to the root certificate. If you happen to have the InCommon RSA
    Server CA installed on your client it will work anyway (that seems to be
    the case with Firefox which comes with its own certificate store) but if
    you use other tools it might not work.
    Please ask your sysadmin to fix this. I have attached the debugging
    output of OpenSSL of the BNL server along with the one of a correctly
    configured server (note the different "Certificate chain" sections). If
    you have difficulties convincing them that something is wrong point them
    to [1] which also reports the issues with the certificate chain.
    Cheers,
    Martin
    [1] https://urldefense.proofpoint.com/v2/url?u=https-3A__www.ssllabs.com_ssltest_analyze.html-3Fd-3Depics.nsls2.bnl.gov&d=DwIFAg&c=aTOVZmpUfPKZuaG9NO7J7Mh6imZbfhL47t9CpZ-pCOw&r=AqgbVvJB57uIxxVMHC9FkQ&m=U1HLZEJlEfTZty86jYktsznTokw06OIGEyC9_gwYG7E&s=Zh8FCHZPWUYAL0sFxc6itzgJYuKhLH_ejDmORJzlnto&e=
    Martin Konrad
    Facility for Rare Isotope Beams
    Michigan State University
    640 South Shaw Lane
    East Lansing, MI 48824-1321, USA
    Tel. 517-908-7253
    Email: [email protected]
Problem with NSLS2 Debian repository? Mark Rivers via Tech-talk
Re: Problem with NSLS2 Debian repository? Flaks, Leonid via Tech-talk
RE: Problem with NSLS2 Debian repository? Mark Rivers via Tech-talk
RE: Problem with NSLS2 Debian repository? tom.cobb--- via Tech-talk
Re: Problem with NSLS2 Debian repository? Konrad, Martin via Tech-talk
Prev: Re: Problem with NSLS2 Debian repository? Konrad, Martin via Tech-talk
Next: Software Engineer position in LIGO Hanks, Jonathan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Tech-talk
ANJ, 02 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
