1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: firewalld configuration for EPICS?
From: Dirk Zimoch via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>, <[email protected]>
Date: Fri, 5 Apr 2019 14:28:32 +0200
I Installed it (without ca-2/tcp) and it work fine.
Thanks again!
On 03.04.19 14:08, Jörn Dreyer wrote:
Am Mittwoch, 3. April 2019, 11:51:11 CEST schrieb Dirk Zimoch via Tech-talk:
Hi
Does anyone already have a firewalld configuration to allow Channel
Access? I.e. something like a /usr/lib/firewalld/services/epics.xml file?
Dirk
Hi Dirk,
you could use the following as a EPICS.xml under /etc/firewalld/services
<?xml version="1.0" encoding="utf-8"?>
<service>
   <short>EPICS Channel Access service</short>
   <port port="ca-1" protocol="tcp"/>
   <port port="ca-1" protocol="udp"/>
   <port port="ca-2" protocol="tcp"/>
   <port port="ca-2" protocol="udp"/>
   <source-port port="ca-1" protocol="tcp"/>
   <source-port port="ca-1" protocol="udp"/>
   <source-port port="ca-2" protocol="tcp"/>
   <source-port port="ca-2" protocol="udp"/>
</service>
And then select EPICS for the zone you need to enable the ports.
Jörn
Re: firewalld configuration for EPICS? Benjamin Franksen via Tech-talk
firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
Re: firewalld configuration for EPICS? Jörn Dreyer via Tech-talk
Prev: CS-Studio WebOPI Florian Feldbauer via Tech-talk
Next: Re: CS-Studio WebOPI Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: firewalld configuration for EPICS? Johnson, Andrew N. via Tech-talk
Next: Re: firewalld configuration for EPICS? Benjamin Franksen via Tech-talk
ANJ, 08 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
