Am Mittwoch, 3. April 2019, 11:51:11 CEST schrieb Dirk Zimoch via Tech-talk:
> Hi
> Does anyone already have a firewalld configuration to allow Channel
> Access? I.e. something like a /usr/lib/firewalld/services/epics.xml file?
> Dirk
Hi Dirk,
you could use the following as a EPICS.xml under /etc/firewalld/services
<?xml version="1.0" encoding="utf-8"?>
<service>
<short>EPICS Channel Access service</short>
<port port="ca-1" protocol="tcp"/>
<port port="ca-1" protocol="udp"/>
<port port="ca-2" protocol="tcp"/>
<port port="ca-2" protocol="udp"/>
<source-port port="ca-1" protocol="tcp"/>
<source-port port="ca-1" protocol="udp"/>
<source-port port="ca-2" protocol="tcp"/>
<source-port port="ca-2" protocol="udp"/>
</service>
And then select EPICS for the zone you need to enable the ports.
Jörn
- Re: firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
- Re: firewalld configuration for EPICS? Ralph Lange via Tech-talk
- firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
RE: ADpython issues with openCV ulrik.pedersen--- via Tech-talk
EPICS June 2019: Registration is open Ralph Lange via Tech-talk
<2019>
2025
2026
Re: firewalld configuration for EPICS? Florian Feldbauer via Tech-talk
<2019>
2025
2026
