1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible?
From: Benjamin Franksen via Tech-talk <[email protected]>
Date: Mon, 8 Apr 2019 16:50:32 +0200
Am 04.04.19 um 20:32 schrieb Mark Rivers via Tech-talk:
> The asyn record does NOT work with SCAN=I/O Intr for TCP devices. The
> problem is that drvAsynIPPort does not have a mechanism to do
> callbacks when there is new data, so asyn client needs to poll.  The
> only code I know of that does this is StreamDevice.
It is easy to add this capability to drvAsynIPPort. But when I call
pasynManager->registerInterruptSource I get an error
"asynManager:registerInterruptSource already registered". Apparently
there is a mechanism in place that generically registers an interrupt
source for /every/ asynOctet interface (and all other standard asyn
interfaces, too). This effectively blocks this feature for all standard
asyn interfaces, so it becomes impossible to add I/O Intr support to
drvAsynIPPort. The code that calls registerInterruptSource in this
generic manner is guarded by an "if (octetCanInterrupt)" but I was
unable to find out what I should do for this flag to be reset. It gets
set by the constructor for class asynPortDriver, but I found no place
where this class actually gets instantiated to an object, i.e. a call to
the constructor takes place. I find all this pretty confusing and would
appreciate hints...
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Christoph Schroeder via Tech-talk
Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
Prev: Re: asynMotor device support and the motor specific driver (asynMotorContorller) Mark Rivers via Tech-talk
Next: Re: asynMotor device support and the motor specific driver (asynMotorContorller) Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
Next: RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
ANJ, 08 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
