1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: limit switch fields in the motor record
From: "Davis, Mark via Tech-talk" <[email protected]>
Date: Tue, 9 Apr 2019 17:56:32 +0000
Is there a reason that the xLS/RxLS limit switch fields in the motor
record only work when the TDIR field's value indicates that the motor is
or was last moving in the direction that would normally trigger the
corresponding limit switch?
This means that that only way to know if a limit switch has REALLY been
triggered is to monitor the bits in the MSTA field.
I am using version 6-9 of the motor record if that makes any difference.
Mark Davis, NSCL/FRIB
Control Systems Software Engineer
[email protected]
RE: limit switch fields in the motor record Mark Rivers via Tech-talk
Re: limit switch fields in the motor record Peterson, Kevin M. via Tech-talk
Prev: Re: firewalld configuration for EPICS? Benjamin Franksen via Tech-talk
Next: RE: limit switch fields in the motor record Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynMotor device support and the motor specific driver (asynMotorContorller) Allan Serra Braga Bugyi via Tech-talk
ANJ, 09 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
