1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: firewalld configuration for EPICS?
From: Benjamin Franksen via Tech-talk <[email protected]>
To: <[email protected]>
Date: Tue, 9 Apr 2019 19:03:22 +0200
Am 09.04.19 um 17:18 schrieb Dirk Zimoch via Tech-talk:
> I had not thought of the multiple IOC problem. In this case it is a
> Fedora Linux VME IOC. Unlikely to run multiple IOCs but not impossible.
> I tried it and naively accessing records on IOC 2 does not work when the
> firewall is up. I get  'CAC: Unable to connect because "No route to
> host"' on the client (caget) even when using the broadcast address.
Ah, I didn't understand that you were talking about firewall on the
machine that runs the IOC(s). My remark was about firewall on the CA client.
Anyway, I thought that services such as a web server use dynamically
assigned (ephemeral) ports for the actual data exchange and the
well-known port only to initiate communication. I guess a firewall can
be configured to allow connections to a web server, so shouldn't it be
possible to do the same for (multiple) IOCs?
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
Re: firewalld configuration for EPICS? Jörn Dreyer via Tech-talk
Re: firewalld configuration for EPICS? Benjamin Franksen via Tech-talk
Prev: Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Benjamin Franksen via Tech-talk
Next: limit switch fields in the motor record Davis, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
Next: Re: firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
ANJ, 10 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
