1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Sequencer segfaults when using put completion with no access to PV
From: "Konrad, Martin via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Benjamin Franksen <[email protected]>
Date: Wed, 10 Apr 2019 13:59:07 +0000
Hi Ben,
I'm experiencing a crash when using the sequencer with
pvPut(foo, SYNC)
while it has no access to PV "foo" due to Access Security constraints
(see backtrace.txt).
I can reproduce this with the latest development version of the
sequencer. Replace all pvPuts in the demo example and insert
asSetFilename("does-not-exist.acf")
at the beginning of demo.stcmd to reproduce the problem.
I'm wondering if there is a way to fail a little nicer.
Thanks!
Martin
P.S.: I'm using Base 3.15.6.
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
#0  0x00007ffff7f147b5 in dbProcessNotify (ppn=0x7fffb00093b8) at ../../../src/ioc/db/dbNotify.c:351
#1  0x00007ffff7f2c411 in dbPutNotifyBlocker::initiatePutNotify (this=0x7fffb00093a0, guard=..., notify=..., dbch=0x7fffb8013100, type=6, count=1, pValue=0x55555562ab68)
    at ../../../src/ioc/db/dbPutNotifyBlocker.cpp:183
#2  0x00007ffff7f28693 in dbContext::initiatePutNotify (this=0x7fffb8000e30, guard=..., chan=..., dbch=0x7fffb8013100, type=6, count=1, pValue=0x55555562ab68, notifyIn=...,
    pId=0x0) at ../../../src/ioc/db/dbContext.cpp:257
#3  0x00007ffff7f2acc1 in dbChannelIO::write (this=0x7fffb8013448, guard=..., type=6, count=1, pValue=0x55555562ab68, notify=..., pId=0x0)
    at ../../../src/ioc/db/dbChannelIO.cpp:107
#4  0x00007ffff7a6dff6 in ca_array_put_callback (type=6, count=1, pChan=0x7fffb8000fb8, pValue=0x55555562ab68, pfunc=<optimized out>, usrarg=<optimized out>)
    at ../oldChannelNotify.cpp:432
#5  0x00007ffff7603ad2 in pvVarPutCallback (var=0x55555562b888, type=pvTypeDOUBLE, count=1, value=0x55555562ab68, arg=0x7fffb00012e0) at ../pv.c:122
#6  0x00007ffff7e4f4a3 in seq_pvPutTmo (ss=0x55555562ae48, chId=3, compType=SYNC, tmo=10) at ../seq_if.c:515
#7  0x000055555555946c in seqg_action_ramp_1_START (seqg_env=0x55555562ae48, seqg_trn=0, seqg_pnst=0x55555562ae7c) at ../demo.st:102
#8  0x00007ffff7e4cb73 in ss_entry (arg=0x55555562ae48) at ../seq_task.c:361
#9  0x00007ffff7ea8479 in start_routine (arg=0x7fffb804f050) at ../../../src/libCom/osi/os/posix/osdThread.c:403
#10 0x00007ffff7a0f164 in start_thread (arg=<optimized out>) at pthread_create.c:486
#11 0x00007ffff7d35def in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Re: Sequencer segfaults when using put completion with no access to PV Benjamin Franksen via Tech-talk
Prev: ADPICam driver observations on Linux Jörn Dreyer via Tech-talk
Next: Stream device character parse 吴煊 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Sequencer segfaults when using put completion with no access to PV Benjamin Franksen via Tech-talk
ANJ, 11 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
