1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: GPIB replies lost?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 19 Apr 2019 13:06:25 -0700
All,
I've come across a new (to me) oddity involving GPIB communication between
a Keysight/Agilent E5810A GPIB to ethernet bridge, and a Keysight/Agilent/HP
3458A DMM.  I'm contacting Keysight support, but thought I'd see if someone
had already run across this issue.
It appears that the DMM is receiving commands which I send.
"BEEP" makes the DMM beep.  If I send an invalid command I can
read the error message through its front panel.
However, valid commands which should send a reply (eg. "ID?") don't
trigger an error, but also timeout without sending back any reply string.
I see the same behavior with a second 3458A.  Also when sending commands
directly through the embedded web server in the E5810A or a python vx11 client.
I tried two different GPIB devices (Keithley and Datron DMMs) with the same
E5810A and cable.  Both send back replies and otherwise behave as I expect.
Michael
Also, a random fact for Friday.  I was on a flight from JFK to LHR
which was listed as 3458 miles.
Re: GPIB replies lost? Eric Norum via Tech-talk
Re: GPIB replies lost? Michael Davidsaver via Tech-talk
Prev: motor R7-0 released Peterson, Kevin M. via Tech-talk
Next: Re: GPIB replies lost? Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 23 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
