1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: GPIB replies lost?
To: Michael Davidsaver <[email protected]>
Cc: Eric Norum via Tech-talk <[email protected]>
Date: Fri, 19 Apr 2019 13:20:02 -0700
AFIAK “ID?” is not a valid SCPI command.  Do you mean”IDN?”  — perhaps this is just a typo in your message here, though.
Are you sure that you have the correct terminators specified?
On Apr 19, 2019, at 1:06 PM, Michael Davidsaver via Tech-talk <[email protected]> wrote:
It appears that the DMM is receiving commands which I send.
"BEEP" makes the DMM beep.  If I send an invalid command I can
read the error message through its front panel.
However, valid commands which should send a reply (eg. "ID?") don't
trigger an error, but also timeout without sending back any reply string.
GPIB replies lost? Michael Davidsaver via Tech-talk
Prev: GPIB replies lost? Michael Davidsaver via Tech-talk
Next: Re: GPIB replies lost? Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 19 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
