1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Base 7.0.2 compile error on Raspberry Pi 3
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: "'[email protected]'" <[email protected]>
Date: Wed, 24 Apr 2019 18:37:17 +0000
I ran into problem with EPICS base libca compilation on Raspberry Pi 3. Perhaps someone has investigated this further.
Base: R7.0.2
Linux raspberrypi 4.9.80-v7+ #1098 SMP Fri Mar 9 19:11:42 GMT 2018 armv7l GNU/Linux
gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1+deb9u1)
GNU Make 4.1
make -C O.linux-arm -f ../Makefile TOP=../.. \
    T_A=linux-arm install
make[4]: Entering directory '/epics/base/modules/libcom/test/O.linux-arm'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/epics/base/modules/libcom/test/O.linux-arm'
make[3]: Leaving directory '/epics/base/modules/libcom/test'
make[2]: Leaving directory '/epics/base/modules/libcom'
make -C ./ca install
make[2]: Entering directory '/epics/base/modules/ca'
make -C ./configure install
make[3]: Entering directory '/epics/base/modules/ca/configure'
make[4]: Entering directory '/epics/base/modules/ca/configure/O.linux-arm'
perl -CSD /epics/base/bin/linux-arm/convertRelease.pl checkRelease
make[4]: Leaving directory '/epics/base/modules/ca/configure/O.linux-arm'
make[3]: Leaving directory '/epics/base/modules/ca/configure'
make -C ./src install
make[3]: Entering directory '/epics/base/modules/ca/src'
make -C ./client install
make[4]: Entering directory '/epics/base/modules/ca/src/client'
make -C O.linux-arm -f ../Makefile TOP=../../.. \
make[5]: Entering directory '/epics/base/modules/ca/src/client/O.linux-arm'
/usr/bin/g++ -o libca.so.4.13.3 -shared -fPIC -L/epics/base/lib/linux-arm -Wl,-rpath,/epics/base/lib/linux-arm           -rdynamic          cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o   -lCom   -lpthread    -lm -lrt -ldl -lgcc
disconnectGovernorTimer.o: file not recognized: File truncated
collect2: error: ld returned 1 exit status
/epics/base/configure/RULES_BUILD:291: recipe for target 'libca.so.4.13.3' failed
make[5]: *** [libca.so.4.13.3] Error 1
make[5]: Leaving directory '/epics/base/modules/ca/src/client/O.linux-arm'
/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-arm' failed
make[4]: *** [install.linux-arm] Error 2
make[4]: Leaving directory '/epics/base/modules/ca/src/client'
/epics/base/configure/RULES_DIRS:84: recipe for target 'client.install' failed
make[3]: *** [client.install] Error 2
make[3]: Leaving directory '/epics/base/modules/ca/src'
/epics/base/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[2]: *** [src.install] Error 2
make[2]: Leaving directory '/epics/base/modules/ca'
../configure/RULES_DIRS:84: recipe for target 'ca.install' failed
make[1]: *** [ca.install] Error 2
make[1]: Leaving directory '/epics/base/modules'
configure/RULES_DIRS:84: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2
Cheers,
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]
(w) www.bnl.gov/nsls2
Re: Base 7.0.2 compile error on Raspberry Pi 3 Johnson, Andrew N. via Tech-talk
RE: Base 7.0.2 compile error on Raspberry Pi 3 Gofron, Kazimierz via Tech-talk
Prev: Re: agilent 34972a Wayne Lewis via Tech-talk
Next: Re: Base 7.0.2 compile error on Raspberry Pi 3 Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 24 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
