1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: MasarService run error
From: =?gb18030?b?MTIz?= via Tech-talk <[email protected]>
To: "=?gb18030?b?dGVjaC10YWxr?=" <[email protected]>
Date: Sun, 28 Apr 2019 10:36:23 +0800
Hi£º
    Recently I compile the masarServer according to the user manual£¬all work well except when I run the masarService. The error is bellow.
Bellow figure is my release.local setting
I also read this
which means either the PYTHONPATH is not set correctly, or MASAR database can not be found or not writable. Check PYTHONPATH, MASAR_SQLITE_DB and its permission.
the bellow is my .bashrc to set the PYTHONPATH
and I just use the example database and I use the command line can open the masar.db.All the command I run in the root account.It seems no error,and I have no idea. Can someone help me? I am looking forward your answer.Thank you very much!
Prev: Re: Stopping IOC boot on failure to load database Hill, Bruce via Tech-talk
Next: asyn based IOC timeout Hinko Kocevar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gen_iocsh_reg.pl Johnson, Andrew N. via Tech-talk
ANJ, 29 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
