1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Coordinated motion of slits
From: George Nicolas Kontogiorgos via Tech-talk <[email protected]>
Date: Mon, 29 Apr 2019 19:13:39 +0000
Hi all,
I am working on a slit setup controlled by Power PMAC using EPICS too. By now I could create a virtual axis as Wayne mentioned on cmd and substitutions files and I can drive the motors using the kinematics transformation on delta tau. The setpoints and readbacks are working fine.
My problem is after the first movement, I can’t perform another movement without resetting my IOC or manually stopping movement with SPMG value. I think that the problem is with DMOV, which never return to one (stopped condition) and do not allow another movement. Should I map this variable on my PLC or motion programs? If so, how could I do that?
Thanks a lot
Best regards
Electrical Engineer
Beamline Software Group (SOL)
Brazilian Synchrotron Light Laboratory (LNLS)
www.lnls.cnpem.br
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Coordinated motion of slits Davis, Mark via Tech-talk
Prev: EDM on stretch Anton Derbenev via Tech-talk
Next: Re: EDM on stretch J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Coordinated motion of slits Davis, Mark via Tech-talk
Next: Re: Coordinated motion of slits Davis, Mark via Tech-talk
ANJ, 29 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
