1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stopping IOC boot on failure to load database
From: Benjamin Franksen via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 30 Apr 2019 17:27:25 +0200
Am 29.04.19 um 17:32 schrieb Ralph Lange via Tech-talk:
> On Mon, 29 Apr 2019 at 17:02, Johnson, Andrew N. via Tech-talk <
> [email protected]> wrote:
>> We might be able to add a routine to iocsh that replicates the VxWorks
>> shellScriptAbort() routine; calling that aborts the current VxWorks target
>> shell and stops reading the startup script. I haven't studied how it works
>> on VxWorks, but my guess is that on entry the shell calls setjmp(), and the
>> abort routine calls longjmp() to return to that context again and clean up.
>> I could see that as a possible cause of lost resources if we're not careful
>> though.
> Sounds dangerous...
> I would rather have a new API for the shell commands (allowing return
> codes) and a glue layer for the existing (old API) commands that returns 0
> in the new API.
I should perhaps mention here that when you embed Lua into a program,
setjmp/longjmp is /the/ standard mechanism for handling errors.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Stopping IOC boot on failure to load database Paduan Donadio, Marcio via Tech-talk
Re: Stopping IOC boot on failure to load database Benjamin Franksen via Tech-talk
Re: Stopping IOC boot on failure to load database Ralph Lange via Tech-talk
Re: Stopping IOC boot on failure to load database Johnson, Andrew N. via Tech-talk
Prev: Re: Fwd: Re: EDM on stretch J. Lewis Muir via Tech-talk
Next: Re: Fwd: Re: EDM on stretch Anton Derbenev via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stopping IOC boot on failure to load database Michael Davidsaver via Tech-talk
Next: Epics 4 pvd::shared-vector , Can't freeze non-unique vector Heinz Junkes via Tech-talk
ANJ, 30 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
