1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fwd: Re: EDM on stretch
From: Anton Derbenev via Tech-talk <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Date: Tue, 30 Apr 2019 14:01:57 -0400
Hello Lewis, John, Christoph,
thanks for your comments and insights - at this moment, we were able to have edm built for Debian 9 internally using the mentioned fork. The package should be available in our stretch staging mirror once that is synchronized (overnight). There are no plans to use it as a baseline viewer solution, just an accommodation for a specific case (building and publishing it is a good bonus). Few notes:
1) I tested that it launches, but no further - will be some time to verify it on some actual screen collection.
2) The patch queue has a patch that has no ownership information.
3) As Lewis suggested, a pull request to epicsdeb edm may be a good idea. There is an outstanding upstream branch PR which doesn't include pristine-tar and debian/ stuff and is likely to be superseded.
Regards!
Anton.
On Tue, Apr 30, 2019 at 10:03 AM J. Lewis Muir via Tech-talk <[email protected]> wrote:
On 04/30, Christoph Schroeder via Tech-talk wrote:
> I build this against base 3.15.5 on Debian 8 and 9. You can use it to
> build the package for the NSLS-II repository. The patches should fix
> all build issues on stretch, but I didn't fix any possible XtPointer
> cast errors though.
Did you submit those patches upstream?  If they are of general use, it
would be great if you could so that everyone could benefit!
Thanks!
Lewis
Re: Fwd: Re: EDM on stretch J. Lewis Muir via Tech-talk
Re: Fwd: Re: EDM on stretch Christoph Schroeder via Tech-talk
Prev: Re: Stopping IOC boot on failure to load database Benjamin Franksen via Tech-talk
Next: Re: Fwd: Re: EDM on stretch J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fwd: Re: EDM on stretch J. Lewis Muir via Tech-talk
ANJ, 01 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
