1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Stopping IOC boot on failure to load database
From: "Hill, Bruce via Tech-talk" <[email protected]>
Date: Tue, 30 Apr 2019 23:42:55 +0000
I can submit a similar pull request for the 3.15 branch.
Even if we choose not to put out another 3.15 release w/ it, that
pull request will be easier to apply as a patch for pre EPICS7 branches.
- Bruce
On 4/29/19 12:38 PM, Jeong Han Lee via Tech-talk wrote:
> Hi Andrew,
>> On 4/29/19 11:19 AM, Jeong Han Lee via Tech-talk wrote:
>>> Is it possible to port or make patch files of this feature into the
>>> existent 3.15.6?
>> The changes that Bruce is proposing could probably be applied to the
>> equivalent files in any EPICS Base release since about 3.14.3, although
>> you wouldn't be able to use the GNU Patch program to do that
>> automatically since the files have been moved around quite a bit and
>> there have been other changes to the sources that would confuse patch.
>   Here is no problem, because I create patch files according to the specific EPICS Base versions. Yes, I know that is
> pain, but only one time pain I will have always.
>> Martin Konrad has suggested that this change be applied to the Base 3.15
>> branch instead of to 7.0, which I would agree to. It sounds like that
>> might be a popular idea.
>   I didn't see his suggestion before. Yes, I also like his proposal.
>   Thank you!
>   Han
>> - Andrew
>>> On 4/27/19 8:07 AM, Hill, Bruce via Tech-talk wrote:
>>>> Added dbLoadSuspendOnError iocsh variable.
>>>> Launchpad merge proposal is here:
>>>> https://code.launchpad.net/~bhill/epics-base/+git/epics-base/+merge/366606
>>>> Cheers,
>>>> - Bruce
>>>> On 4/15/19 11:44 AM, Mooney, Tim M. via Tech-talk wrote:
>>>>> I've long wanted to give autosave the ability to retain PV values of
>>>>> databases that loaded successfully in the past, but that failed or
>>>>> were commented out during one or more reboots, so they can be
>>>>> restored when the database next boots successfully.  I don't have
>>>>> plans to do this soon, but it does seem a reasonable thing to do,
>>>>> and not all that hard.
>>>>> Tim Mooney ([email protected]) (630)252-5417
>>>>> Beamline Controls Group (www.aps.anl.gov)
>>>>> Advanced Photon Source, Argonne National Lab
>>>>> *From:* [email protected]
>>>>> <[email protected]> on behalf of Paduan Donadio, Marcio
>>>>> via Tech-talk <[email protected]>
>>>>> *Sent:* Monday, April 15, 2019 12:49 PM
>>>>> *To:* [email protected]
>>>>> *Subject:* Stopping IOC boot on failure to load database
>>>>> Hello, all.
>>>>> We are thinking about creating a function in EPICS base like
>>>>> stopOnDbLoadErrorto be called before dbLoad* functions. The idea is
>>>>> to freeze the IOC boot with a message on the IOC shell or to
>>>>> completely abort, exiting. Alternatively, we could also place an
>>>>> additional optional parameter to the dbLoad* functions to have the
>>>>> same behavior.
>>>>> What we intend with this is:
>>>>> 1.) bring the error to the attention of the responsible IOC engineer
>>>>> and,
>>>>> 2.) stop corruption of Autosave files due to missing PVs.
>>>>> Do you think it would be something valuable to be added in an
>>>>> official EPICS release?
>>>>> Thank you,
>>>>> Márcio Paduan Donadio
>>>>> Control Systems Engineer
>>>>> SLAC
>>>> Bruce Hill
>>>> Member Technical Staff
>>>> SLAC National Accelerator Lab
>>>> 2575 Sand Hill Road M/S 10
>>>> Menlo Park, CA  94025
Bruce Hill
Stopping IOC boot on failure to load database Paduan Donadio, Marcio via Tech-talk
Re: Stopping IOC boot on failure to load database Mooney, Tim M. via Tech-talk
Re: Stopping IOC boot on failure to load database Hill, Bruce via Tech-talk
Re: Stopping IOC boot on failure to load database Jeong Han Lee via Tech-talk
Re: Stopping IOC boot on failure to load database Johnson, Andrew N. via Tech-talk
Prev: Re: Fwd: Re: EDM on stretch Johnson, Andrew N. via Tech-talk
Next: Re: Fwd: Re: EDM on stretch Christoph Schroeder via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Stopping IOC boot on failure to load database Jeong Han Lee via Tech-talk
Next: Re: Stopping IOC boot on failure to load database Benjamin Franksen via Tech-talk
ANJ, 01 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
