1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: medm display on Linux and video acceleration
From: Gerrit Kühn via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 2 May 2019 15:25:20 +0200
Dear all,
On a rather recent Linux installation I saw the strange issue that some of
our medm screens had channels that did not update properly. Most of the
affected displays used rectangles, often several of them stacked. When
opening the screen, many of these stayed white. Proper operation could be
triggered by forcing redraw of the screen by switching forth and back from
a different virtual desktop, but the rectabgles became white again when
changing the size of the window. Also, in some windows the wrong rectangle
(from multiple stacked ones) was displayed.
After trying a lot of things (comparing with other machines' displays,
using different window managers etc.), it turned out that the issue was
tied to the local display. Running medm over an ssh tunnel, just
displaying on a different machine, worked just fine.
In the end I could completely work around the issue by changing the
acceleration method for our Intel-Kabylake-driven monitors from the
default SNA to UXA by adding
Option      "AccelMethod" "uxa"
to the Xorg configuration. With that, everything appears to be back to
normal.
Admittedly, we don't use the latest medm version here (ours is 3.1.9), but
I briefly looked into the repository and saw no changes that seemed
releated to an issue like this. Did anybody already see something like
this before? In any case, this is for the record, if anybody else might
stumble upon this.
cu
  Gerrit
Prev: RE: Problem with NSLS2 Debian repository? michael.abbott--- via Tech-talk
Next: Re: IOClog Konrad, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOClog Konrad, Martin via Tech-talk
Next: Software Engineer position in LIGO Hanks, Jonathan via Tech-talk
ANJ, 02 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
