1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Pmac Slits
From: "giles.knap--- via Tech-talk" <[email protected]>
To: George Nicolas Kontogiorgos <[email protected]>, "Davis, Mark" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 May 2019 08:10:49 +0000
Hi George,
Your fix looks like it is legitimate. I only added PMAC_PRE_FAST_READ recently and have been having issues with my test hardware for PowerPmac, so might not have seen the problem here.
However, I am confused as to why this bug has not affected the turbo pmac tests I did.
I will review the pull request.
giles.
From: George Nicolas Kontogiorgos <[email protected]>
Sent: 02 May 2019 19:05:25
To: Knap, Giles (DLSLtd,RAL,LSCI); Davis, Mark; [email protected]
Subject: RES: Pmac Slits
Hi Giles,
I could solve the problem od DMOV not returning to stopped status by changing the condition on callback function on pmacCSController.cpp. There is a if that compare type with pmacMessageBroker::PMAC_PRE_FAST_READ (the values are 2 and 3 respectively) and the result is false. It results that the code inside this if (which get the coordinate system status) is never executed. As consequence, EPICS can not get CS status and DMOV never come back to stopped state.
To solve the problem I supposed that we are talking about a fast read, not pre fast read (the difference is that they have the same rate but variables on pre are read  first, according to comments on pmacMessageBroker.cpp) since the variable type has value 2.
After this modification DMOV work fine, since status is being refreshed.
I did a pull request on dls repo in order to fix this issue. Feel free to suggest better modifications.
Hi Mark,
After all this studies I figured out that DMOV or MOVN doesn't need to be mapped manually, this is made by program itself (the system polls the status).
I could solve the problem of slits at all by Wayne method.
Regards
George
-----Mensagem original-----
De: [email protected] <[email protected]>
Enviada em: terça-feira, 30 de abril de 2019 04:07
Para: George Nicolas Kontogiorgos <[email protected]>; Davis, Mark <[email protected]>
Assunto: Re: Pmac Slits
I'm seeing this exact issue on my power clipper. It has started happening since I factory reset the configuration.
I have yet to work out which setting(s) are responsible but intend to spend time on this next week.
From: [email protected] <[email protected]> on behalf of Davis, Mark via Tech-talk <[email protected]>
Sent: 29 April 2019 18:31:52
To: George Nicolas Kontogiorgos; [email protected]
Hi George,
I haven't yet had a chance to try a configuration like one Wayne described (and Giles helped me understand).  Hopefully I will have time this week to give it a try.
The behavior you describe for the DMOV and MOVN does sound like an issue that needs to be addressed.
Are you also using a Delta Tau Power Brick (or some other Power PMAC model) controller as I am?
Regarding your Tech-Talk subscription:  I would expect that once you are subscribed, you should be able to include the Tech-Talk list email in your To or Reply-To list (we will see momentarily, as I included it in the To list for this email).
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]<mailto:[email protected]>
On 4/29/2019 7:30 AM, George Nicolas Kontogiorgos wrote:
Hello Davis!
I am George and I and @Luciano Carneiro Guedes<mailto:[email protected]> are working with coordinated motion on a 2 motor slit controlled by PowerPMAC and integrated with EPICS (The same setup as you).
I saw your message on EPICS techtalk<https://urldefense.proofpoint.com/v2/url?u=https-3A__epics.anl.gov_tech-2Dtalk_2019_msg00684.php&d=DwMFAg&c=nE__W8dFE-shTxStwXtp0A&r=D7ZiziuMQuq40HlGYOZPBg&m=k7CLCJno5gjAruO8gtDsAKM9ugfmt3N1wib_vy4Mcn8&s=TuASR5lFnez6KMJ0vYQrq8TzXXQvv2A_q-ps57L7SFg&e=> and I would like to know you if your setup is running well.
Here we achieved  the point that we can drive a virtual motor using motor record as Wayne Lewis sad. The problem is that the DMOV (or MOVN) is not set to 1 (not moving) when all motors reach the setpoint specified by the kinematics.
I could not reply the message on techtalk because I subscribed on it after you send those messages (and I don't know if it is possible to reply now.)
Best regards
Electrical Engineer
Beamline Software Group (SOL)
Brazilian Synchrotron Light Laboratory (LNLS) www.lnls.cnpem.br<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.lnls.cnpem.br_&d=DwMFAg&c=nE__W8dFE-shTxStwXtp0A&r=D7ZiziuMQuq40HlGYOZPBg&m=k7CLCJno5gjAruO8gtDsAKM9ugfmt3N1wib_vy4Mcn8&s=bn2OpbndTqv8qG1bvTHojoFLoD_4u5TpWmPDvtkn--s&e=>
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Pmac Slits Davis, Mark via Tech-talk
RES: Pmac Slits George Nicolas Kontogiorgos via Tech-talk
Prev: Re: Problem with NSLS2 Debian repository? Konrad, Martin via Tech-talk
Next: Re: firewalld configuration for EPICS? Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RES: Pmac Slits George Nicolas Kontogiorgos via Tech-talk
Next: Re: RES: Pmac Slits Davis, Mark via Tech-talk
ANJ, 03 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
