1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Pmac Slits
From: "Davis, Mark via Tech-talk" <[email protected]>
To: George Nicolas Kontogiorgos <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 29 Apr 2019 17:31:52 +0000
Hi George,
I haven't yet had a chance to try a configuration like one Wayne described (and Giles helped me understand).  Hopefully I will have time this week to give it a try.
The behavior you describe for the DMOV and MOVN does sound like an issue that needs to be addressed.
Are you also using a Delta Tau Power Brick (or some other Power PMAC model) controller as I am?
Regarding your Tech-Talk subscription:  I would expect that once you are subscribed, you should be able to include the Tech-Talk list email in your To or Reply-To list (we will see momentarily, as I included it in the To list for this email).
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
On 4/29/2019 7:30 AM, George Nicolas Kontogiorgos wrote:
Hello Davis!
I am George and I and @Luciano Carneiro Guedes are working with coordinated motion on a 2 motor slit controlled by PowerPMAC and integrated with EPICS (The same setup as you).
I saw your message on EPICS techtalk and I would like to know you if your setup is running well.
Here we achieved  the point that we can drive a virtual motor using motor record as Wayne Lewis sad. The problem is that the DMOV (or MOVN) is not set to 1 (not moving) when all motors reach the setpoint specified by the kinematics.
I could not reply the message on techtalk because I subscribed on it after you send those messages (and I don’t know if it is possible to reply now…)
Best regards
Electrical Engineer
Beamline Software Group (SOL)
Brazilian Synchrotron Light Laboratory (LNLS)
www.lnls.cnpem.br
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Prev: Re: gen_iocsh_reg.pl Johnson, Andrew N. via Tech-talk
Next: EDM on stretch Anton Derbenev via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: asyn based IOC timeout Hinko Kocevar via Tech-talk
Next: RES: Pmac Slits George Nicolas Kontogiorgos via Tech-talk
ANJ, 02 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
