Thanks for your inputs!
I will try Andrew's suggestion next week (removing caClientCallbackThreadId=0).
Michael -- I will look at how the sequencer does it. Thanks for the suggestion!
Matt -- I did set the PYEPICS_LIBCA to the proper path and set AUTO_CLEANUP to False. I tried several different things, even manually cleaning up the caches. The whole issue, in my opinion, is what Andrew diagnosed: zeroing the common index makes it impossible to do anything with the libca context afterwards.
Versions:
Debian 9.9 EPICS R3.15.6 (FRIB package)
pyepics 3.4.0 (FRIB package) pyDevSup: 1.1 (FRIB package)
On Fri, May 3, 2019 at 5:33 PM Johnson, Andrew N. via Tech-talk < [email protected]> wrote: On 5/3/19 3:40 PM, Michael Davidsaver via Tech-talk wrote:
> On 5/3/19 12:43 PM, Bruno Martins via Tech-talk wrote:
>> I believe that the following are true:
>> - pyepics dynamically loads libca, which ends up being the same instance as the one loaded by the IOC itself (for dbCa)
>> - pyepics does not share the same context with dbCa if it is run on its own thread and the proper context_create call is performed
>> - Even when not sharing libca contexts, the variable caClientCallbackThreadId ends up being the same for pyepics and dbCa.
>> - cacExitHandler runs when the IOC is exiting and sets caClientCallbackThreadId=0 [1]
>> - Any subsequent libca call by pyepics (during its cleanup) that tries to use caClientCallbackThreadId will segfault.
>> Possible solutions:
>> - Register pyepics' finalize_libca with pyDevSup's addHook('AtIocExit',...), but this runs after dbCa cleanup. Can it be made to run before? Can there be a 'BeforeIocExit' hook?
> Unfortunately no. Though this does suggest a rethink of addHook(),
> and maybe also epicsAtExit() to be able to better express ordering
> requirements.
Is pyepics registing an epicsAtExit() hook? These always run in the
reverse order in which they are registered, so pyepics should be
initializing its CA context and registering such a hook when it first
gets called, then cleaning up inside that hook routine, which will be
called before the hook routine of any subsystem that got initialized
before it.
>> - Remove caClientCallbackThreadId=0 in libca. I have no idea about the implications.
I removed a similar statement that was zeroing the caClientContextId
last february (bug #1743076 on Launchpad, SHA
de442e9584d9214533e5e90af4270e34fd45d947) which was included in
Base-3.15.6 and had a similar effect. I don't know whether that will
resolve your problem, but I would definitely recommend trying it.
>> - Something else?
>> Of course, I understand that both the IOC itself and pyepics kind of expect to be the sole users of libca in their processes. This assumption doesn't hold when I have pyepics inside a IOC.
> The IOC isn't making such an assumption. eg. the sequencer creates its own CA context.
I don't think the two subsystems are sharing a context, the problem as I
see it is that when the cacExitHandler() runs in one thread it zeroes
the common index into the thread-private table, thus making it
impossible for any other thread that's still running in a different
context to read the value from its copy of the thread-local variable
table. I see no reason to yank the ID here at all.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- libca bug? Bruno Martins via Tech-talk
- Re: libca bug? Michael Davidsaver via Tech-talk
- Re: libca bug? Johnson, Andrew N. via Tech-talk
Re: libca bug? Matt Newville via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 03 May 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
