1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Device sending continuously Data
From: Benjamin Hetz via Tech-talk <[email protected]>
To: [email protected]
Date: Sun, 5 May 2019 09:40:02 +0200
Hello,
I am having a device that does continuously send data via serial port in the form 20h21h<lowbyte1><highbyte1><lowbyte2><highbyte2>17h18h. In a rate of ~ 10 Hz. I guess one can get the two integers by using stream device and use a calc record to combine the low and high bytes. But stream device does not seem to be appropriate here. Are there any other suggestion?
Thanks a lot, Benjamin
Re: Device sending continuously Data Dirk Zimoch via Tech-talk
Prev: Re: firewalld configuration for EPICS? Michael Davidsaver via Tech-talk
Next: Re: firewalld configuration for EPICS? Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: libca bug? Michael Davidsaver via Tech-talk
Next: Re: Device sending continuously Data Dirk Zimoch via Tech-talk
ANJ, 06 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
