Hi Benjamin,
It should work with a StreamDevice protocol like this:
getData {
maxInput=8;
in 0x20 0x21 "%#2r%(\$1)#2r" 0x17 0x18;
record (ai, "$(P)Data1") {
field (DTYP, "stream")
field (INP, "@$(PROTOCOLFILE) getData($(P)Data2) $(ASYNPORT)")
field (SCAN, "I/O Intr")
record (ai, "$(P)Data2") {
Dirk
On 05.05.19 09:40, Benjamin Hetz via Tech-talk wrote:
Hello,
I am having a device that does continuously send data via serial port in
the form 20h21h<lowbyte1><highbyte1><lowbyte2><highbyte2>17h18h. In a
rate of ~ 10 Hz.
I guess one can get the two integers by using stream device and use a
calc record to combine the low and high bytes. But stream device does
not seem to be appropriate here. Are there any other suggestion?
Thanks a lot, Benjamin
- Device sending continuously Data Benjamin Hetz via Tech-talk
Re: firewalld configuration for EPICS? Matt Newville via Tech-talk
RE: Pmac Slits George Nicolas Kontogiorgos via Tech-talk
<2019>
2025
2026
Simple test fails to find subroutine in registry Matt Rippa via Tech-talk
<2019>
2025
2026
