I'm trying to use VS 2017 to compile MCA extension for Matlab 2019 on Windows 10. My choice of EPICS base is 3.15.5.
Here is the compile output, reached after following README_WIN7 in MCA sources.
First the error only:
link /nologo /manifest /DLL /EXPORT:mexFunction /EXPORT:mexfilerequiredapiversion C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\mca.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\MCAError.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\Channel.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\cpp_mexapi_version.obj c:\base-3.15.5\lib\windows-x64\Com.lib c:\base-3.15.5\lib\windows-x64\ca.lib /LIBPATH:"C:\Program Files\MATLAB\R2019a\extern\lib\win64\microsoft" libmx.lib libmex.lib libmat.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib libMatlabDataArray.lib libMatlabEngine.lib /out:mca.mexw64
Creating library mca.lib and object mca.exp
Channel.obj : error LNK2019: unresolved external symbol dbr_size referenced in function "private: void __cdecl Channel::AllocChanMem(void)" (?AllocChanMem@Channel@@AEAAXXZ)
Channel.obj : error LNK2019: unresolved external symbol dbr_value_size referenced in function "private: void __cdecl Channel::AllocChanMem(void)" (?AllocChanMem@Channel@@AEAAXXZ)
Channel.obj : error LNK2019: unresolved external symbol dbf_text_dim referenced in function "private: void __cdecl Channel::AllocChanMem(void)" (?AllocChanMem@Channel@@AEAAXXZ)
mca.mexw64 : fatal error LNK1120: 3 unresolved externals
I must be missing some lib or ??
Now for the whole output (lots!):
Microsoft Windows [Version 10.0.17134.648]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\Users\hinkokocevar>cd c:\mca-master
c:\mca-master>compile.bat
c:\mca-master>call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvarsall.bat" amd64
** Visual Studio 2017 Developer Command Prompt v15.0.26228.76
** Copyright (c) 2017 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
Verbose mode is on.
... Looking for compiler 'Intel Parallel Studio XE 2015 with Microsoft Visual Studio 2015 (C)' ...
... Looking for environment variable 'ICPP_COMPILER15' ...No.
Did not find installed compiler 'Intel Parallel Studio XE 2015 with Microsoft Visual Studio 2015 (C)'.
... Looking for compiler 'Intel Parallel Studio XE 2016 with Microsoft Visual Studio 2015 (C)' ...
... Looking for environment variable 'ICPP_COMPILER16' ...No.
Did not find installed compiler 'Intel Parallel Studio XE 2016 with Microsoft Visual Studio 2015 (C)'.
... Looking for compiler 'Intel Parallel Studio XE 2017 with Microsoft Visual Studio 2015 (C)' ...
... Looking for environment variable 'ICPP_COMPILER17' ...No.
Did not find installed compiler 'Intel Parallel Studio XE 2017 with Microsoft Visual Studio 2015 (C)'.
... Looking for compiler 'Intel Parallel Studio XE 2017 with Microsoft Visual Studio 2017 (C)' ...
Did not find installed compiler 'Intel Parallel Studio XE 2017 with Microsoft Visual Studio 2017 (C)'.
... Looking for compiler 'Intel Parallel Studio XE 2018 with Microsoft Visual Studio 2015 (C)' ...
... Looking for environment variable 'ICPP_COMPILER18' ...No.
Did not find installed compiler 'Intel Parallel Studio XE 2018 with Microsoft Visual Studio 2015 (C)'.
... Looking for compiler 'Intel Parallel Studio XE 2018 with Microsoft Visual Studio 2017 (C)' ...
Did not find installed compiler 'Intel Parallel Studio XE 2018 with Microsoft Visual Studio 2017 (C)'.
... Looking for compiler 'Intel Parallel Studio XE 2019 with Microsoft Visual Studio 2015 (C)' ...
... Looking for environment variable 'ICPP_COMPILER19' ...No.
Did not find installed compiler 'Intel Parallel Studio XE 2019 with Microsoft Visual Studio 2015 (C)'.
... Looking for compiler 'Intel Parallel Studio XE 2019 with Microsoft Visual Studio 2017 (C)' ...
Did not find installed compiler 'Intel Parallel Studio XE 2019 with Microsoft Visual Studio 2017 (C)'.
... Looking for compiler 'MinGW64 Compiler (C)' ...
... Looking for environment variable 'MW_MINGW64_LOC' ...No.
Did not find installed compiler 'MinGW64 Compiler (C)'.
... Looking for compiler 'Microsoft Visual C++ 2015 (C)' ...
... Looking for registry setting 'HKLM\SOFTWARE\Microsoft\VisualStudio\SxS\VC7' 14.0 ...No.
... Looking for registry setting 'HKCU\SOFTWARE\Microsoft\VisualStudio\SxS\VC7' 14.0 ...No.
... Looking for registry setting 'HKLM\SOFTWARE\Wow6432Node\Microsoft\VisualStudio\SxS\VC7' 14.0 ...No.
... Looking for registry setting 'HKCU\SOFTWARE\Wow6432Node\Microsoft\VisualStudio\SxS\VC7' 14.0 ...No.
Did not find installed compiler 'Microsoft Visual C++ 2015 (C)'.
... Looking for compiler 'Microsoft Visual C++ 2017 (C)' ...
... Looking for registry setting 'HKLM\SOFTWARE\Microsoft\VisualStudio\SxS\VS7' 15.0 ...No.
... Looking for registry setting 'HKCU\SOFTWARE\Microsoft\VisualStudio\SxS\VS7' 15.0 ...No.
... Looking for registry setting 'HKLM\SOFTWARE\Wow6432Node\Microsoft\VisualStudio\SxS\VS7' 15.0 ...Yes ('C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\').
... Executing command 'set "vcroot=C:\Program Files (x86)\Microsoft Visual Studio\2017\Community"&for /f "delims= " %a in ('type "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\Microsoft.VCToolsVersion.default.txt"') do @if exist "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\%a\bin\HostX64\x64\cl.exe" call echo %vcroot%' ...Yes ('C:\Program Files (x86)\Microsoft Visual Studio\2017\Community').
... Looking for registry setting 'HKLM\SOFTWARE\Microsoft\Microsoft SDKs\Windows\v10.0' InstallationFolder ...No.
... Looking for registry setting 'HKCU\SOFTWARE\Microsoft\Microsoft SDKs\Windows\v10.0' InstallationFolder ...No.
... Looking for registry setting 'HKLM\SOFTWARE\Wow6432Node\Microsoft\Microsoft SDKs\Windows\v10.0' InstallationFolder ...Yes ('C:\Program Files (x86)\Windows Kits\10\').
... Executing command 'set "vcroot=C:\Program Files (x86)\Microsoft Visual Studio\2017\Community"&for /f "delims= " %a in ('type "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\Microsoft.VCToolsVersion.default.txt"') do @if exist "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\%a\bin\HostX64\x64\cl.exe" call echo %vcroot%\VC\Tools\MSVC\%a' ...Yes ('C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017').
... Looking for file 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvarsall.bat' ...Yes.
... Looking for folder 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build' ...Yes.
... Looking for registry setting 'HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows Kits\Installed Roots' KitsRoot10 ...Yes ('C:\Program Files (x86)\Windows Kits\10\').
... Executing command 'echo off&set "sdkversion="&(for /f %a IN ('dir "C:\Program Files (x86)\Windows Kits\10\include\" /b /ad-h /on') do ( @if exist "C:\Program Files (x86)\Windows Kits\10\include\%a\ucrt\" set "sdkversion=%a" ))&call echo %sdkversion%' ...Yes ('10.0.14393.0').
Found installed compiler 'Microsoft Visual C++ 2017 (C)'.
MEX configured to use 'Microsoft Visual C++ 2017 (C)' for C language compilation.
Warning: The MATLAB C and Fortran API has changed to support MATLAB
variables with more than 2^32-1 elements. You will be required
to update your code to utilize the new API.
You can find more information about this at:
https://www.mathworks.com/help/matlab/matlab_external/upgrading-mex-files-to-use-64-bit-api.html.
Verbose mode is on.
... Looking for compiler 'Intel Parallel Studio XE 2015 for C++ with Microsoft Visual Studio 2015' ...
Did not find installed compiler 'Intel Parallel Studio XE 2015 for C++ with Microsoft Visual Studio 2015'.
... Looking for compiler 'Intel Parallel Studio XE 2016 for C++ with Microsoft Visual Studio 2015' ...
Did not find installed compiler 'Intel Parallel Studio XE 2016 for C++ with Microsoft Visual Studio 2015'.
... Looking for compiler 'Intel Parallel Studio XE 2017 for C++ with Microsoft Visual Studio 2015' ...
Did not find installed compiler 'Intel Parallel Studio XE 2017 for C++ with Microsoft Visual Studio 2015'.
... Looking for compiler 'Intel Parallel Studio XE 2017 for C++ with Microsoft Visual Studio 2017' ...
Did not find installed compiler 'Intel Parallel Studio XE 2017 for C++ with Microsoft Visual Studio 2017'.
... Looking for compiler 'Intel Parallel Studio XE 2018 for C++ with Microsoft Visual Studio 2015' ...
Did not find installed compiler 'Intel Parallel Studio XE 2018 for C++ with Microsoft Visual Studio 2015'.
... Looking for compiler 'Intel Parallel Studio XE 2018 for C++ with Microsoft Visual Studio 2017' ...
Did not find installed compiler 'Intel Parallel Studio XE 2018 for C++ with Microsoft Visual Studio 2017'.
... Looking for compiler 'Intel Parallel Studio XE 2019 for C++ with Microsoft Visual Studio 2015' ...
Did not find installed compiler 'Intel Parallel Studio XE 2019 for C++ with Microsoft Visual Studio 2015'.
... Looking for compiler 'Intel Parallel Studio XE 2019 for C++ with Microsoft Visual Studio 2017' ...
Did not find installed compiler 'Intel Parallel Studio XE 2019 for C++ with Microsoft Visual Studio 2017'.
... Looking for compiler 'MinGW64 Compiler (C++)' ...
Did not find installed compiler 'MinGW64 Compiler (C++)'.
... Looking for compiler 'MinGW64 Compiler with Windows 10 SDK or later (C++)' ...
Did not find installed compiler 'MinGW64 Compiler with Windows 10 SDK or later (C++)'.
... Looking for compiler 'Microsoft Visual C++ 2015' ...
Did not find installed compiler 'Microsoft Visual C++ 2015'.
... Looking for compiler 'Microsoft Visual C++ 2017' ...
Found installed compiler 'Microsoft Visual C++ 2017'.
MEX configured to use 'Microsoft Visual C++ 2017' for C++ language compilation.
Verbose mode is on.
Set PATH = C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\bin\HostX64\x64\;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\vcpackages;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\Tools;C:\Program Files (x86)\Windows Kits\10\\Bin\10.0.14393.0\x64;C:\Program Files (x86)\Windows Kits\10\\Bin\10.0.14393.0\x86;C:\Program Files (x86)\Windows Kits\10\\Bin\x64;C:\Program Files (x86)\Windows Kits\10\\Bin\x86;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\bin\HostX64\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCPackages;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\CommonExtensions\Microsoft\TestWindow;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\CommonExtensions\Microsoft\TeamFoundation\Team Explorer;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\MSBuild\15.0\bin\Roslyn;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Team Tools\Performance Tools;C:\Program Files (x86)\Microsoft Visual Studio\Shared\Common\VSPerfCollectionTools\;C:\Program Files (x86)\Windows Kits\10\bin\x64;C:\Program Files (x86)\Windows Kits\10\bin\10.0.14393.0\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\\MSBuild\15.0\bin;C:\Windows\Microsoft.NET\Framework64\v4.0.30319;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\Tools\;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\MATLAB\R2019a\bin;C:\StrawberryPERL\c\bin;C:\StrawberryPERL\perl\site\bin;C:\StrawberryPERL\perl\bin;c:\base-3.15.5\bin\windows-x64;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Users\hinkokocevar\AppData\Local\Microsoft\WindowsApps;
Set INCLUDE = C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\include;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\atlmfc\include;C:\Program Files (x86)\Windows Kits\10\\include\10.0.14393.0\ucrt;C:\Program Files (x86)\Windows Kits\10\\include\10.0.14393.0\shared;C:\Program Files (x86)\Windows Kits\10\\include\10.0.14393.0\um;C:\Program Files (x86)\Windows Kits\10\\include\10.0.14393.0\winrt;C:\Program Files\MATLAB\R2019a\extern\include;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\ATLMFC\include;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\include;C:\Program Files (x86)\Windows Kits\10\include\10.0.14393.0\ucrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.14393.0\shared;C:\Program Files (x86)\Windows Kits\10\include\10.0.14393.0\um;C:\Program Files (x86)\Windows Kits\10\include\10.0.14393.0\winrt;
Set LIB = C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\atlmfc\lib\x64;C:\Program Files (x86)\Windows Kits\10\\Lib\10.0.14393.0\ucrt\x64;C:\Program Files (x86)\Windows Kits\10\\lib\10.0.14393.0\um\x64;C:\Program Files\MATLAB\R2019a\lib\win64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\ATLMFC\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\lib\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.14393.0\ucrt\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.14393.0\um\x64;
Set LIBPATH = C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\atlmfc\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\ATLMFC\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\lib\x64;C:\Program Files (x86)\Windows Kits\10\UnionMetadata;C:\Program Files (x86)\Windows Kits\10\References;C:\Windows\Microsoft.NET\Framework64\v4.0.30319;
Options file details
Compiler location: C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\
Options file: C:\Users\hinkokocevar\AppData\Roaming\MathWorks\MATLAB\R2019a\mex_C++_win64.xml
CMDLINE200 : link /nologo /manifest /DLL /EXPORT:mexFunction /EXPORT:mexfilerequiredapiversion C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\mca.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\MCAError.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\Channel.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\cpp_mexapi_version.obj c:\base-3.15.5\lib\windows-x64\Com.lib c:\base-3.15.5\lib\windows-x64\ca.lib /LIBPATH:"C:\Program Files\MATLAB\R2019a\extern\lib\win64\microsoft" libmx.lib libmex.lib libmat.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib libMatlabDataArray.lib libMatlabEngine.lib /out:mca.mexw64
CMDLINE250 : mt -outputresource:mca.mexw64;2 -manifest "mca.mexw64.manifest"
CMDLINE300 : del "mca.exp" "mca.lib" "mca.mexw64.manifest" "mca.ilk"
COMPILER : cl
COMPFLAGS : /Zp8 /GR /W3 /EHs /nologo /MD
COMPDEFINES : /DDB_TEXT_GLBLSOURCE /DMSCC /DWIN32 /DWIN64 /DMATLAB_DEFAULT_RELEASE=R2017b /DUSE_MEX_CMD /D_CRT_SECURE_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0 /DMATLAB_MEX_FILE
MATLABMEX : /DMATLAB_MEX_FILE
OPTIMFLAGS : /O2 /Oy- /DNDEBUG
INCLUDE : -I"c:\base-3.15.5\include" -I"c:\base-3.15.5\include\os\WIN32" -I"c:\base-3.15.5\include\compiler\msvc" -I"C:\Program Files\MATLAB\R2019a\extern\include" -I"C:\Program Files\MATLAB\R2019a\simulink\include"
DEBUGFLAGS : /Z7
LINKER : link
LINKFLAGS : /nologo /manifest
LINKTYPE : /DLL
LINKEXPORT : /EXPORT:mexFunction
LINKEXPORTVER : /EXPORT:mexFunction /EXPORT:mexfilerequiredapiversion
LINKLIBS : c:\base-3.15.5\lib\windows-x64\Com.lib c:\base-3.15.5\lib\windows-x64\ca.lib /LIBPATH:"C:\Program Files\MATLAB\R2019a\extern\lib\win64\microsoft" libmx.lib libmex.lib libmat.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib libMatlabDataArray.lib libMatlabEngine.lib
LINKDEBUGFLAGS : /debug /PDB:"mca.mexw64.pdb"
LINKOPTIMFLAGS :
OBJEXT : .obj
LDEXT : .mexw64
SETENV : set COMPILER=cl
set COMPFLAGS=/c /Zp8 /GR /W3 /EHs /nologo /MD /DDB_TEXT_GLBLSOURCE /DMSCC /DWIN32 /DWIN64 /DMATLAB_DEFAULT_RELEASE=R2017b /DUSE_MEX_CMD /D_CRT_SECURE_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0 /DMATLAB_MEX_FILE /DMATLAB_MEX_FILE
set OPTIMFLAGS=/O2 /Oy- /DNDEBUG
set DEBUGFLAGS=/Z7
set LINKER=link
set LINKFLAGS=/nologo /manifest /export:%ENTRYPOINT% /DLL c:\base-3.15.5\lib\windows-x64\Com.lib c:\base-3.15.5\lib\windows-x64\ca.lib /LIBPATH:"C:\Program Files\MATLAB\R2019a\extern\lib\win64\microsoft" libmx.lib libmex.lib libmat.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib libMatlabDataArray.lib libMatlabEngine.lib /EXPORT:mexFunction
set LINKDEBUGFLAGS=/debug /PDB:"%OUTDIR%%MEX_NAME%.mexw64.pdb"
set NAME_OUTPUT=/out:"%OUTDIR%%MEX_NAME%%MEX_EXT%"
VCROOT : C:\Program Files (x86)\Microsoft Visual Studio\2017\Community
SDKROOT : C:\Program Files (x86)\Windows Kits\10\
VSINSTALLDIR : C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\
VCINSTALLDIR : C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017
VCVARSALLDIR : C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build
KITSROOT : C:\Program Files (x86)\Windows Kits\10\
SDKVERSION : 10.0.14393.0
MATLABROOT : C:\Program Files\MATLAB\R2019a
ARCH : win64
SRC : "c:\mca-master\mca.cpp";"c:\mca-master\MCAError.cpp";"c:\mca-master\Channel.cpp";"C:\Program Files\MATLAB\R2019a\extern\version\cpp_mexapi_version.cpp"
OBJ : C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\mca.obj;C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\MCAError.obj;C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\Channel.obj;C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\cpp_mexapi_version.obj
OBJS : C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\mca.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\MCAError.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\Channel.obj C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\cpp_mexapi_version.obj
SRCROOT : c:\mca-master\mca
DEF : C:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\mca.def
EXP : "mca.exp"
LIB : "mca.lib"
EXE : mca.mexw64
ILK : "mca.ilk"
MANIFEST : "mca.mexw64.manifest"
TEMPNAME : mca
EXEDIR :
EXENAME : mca
OPTIM : /O2 /Oy- /DNDEBUG
LINKOPTIM :
CMDLINE100_0 : cl /c /Zp8 /GR /W3 /EHs /nologo /MD /O2 /Oy- /DNDEBUG /DDB_TEXT_GLBLSOURCE /DMSCC /DWIN32 /DWIN64 /DMATLAB_DEFAULT_RELEASE=R2017b /DUSE_MEX_CMD /D_CRT_SECURE_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0 /DMATLAB_MEX_FILE -I"c:\base-3.15.5\include" -I"c:\base-3.15.5\include\os\WIN32" -I"c:\base-3.15.5\include\compiler\msvc" -I"C:\Program Files\MATLAB\R2019a\extern\include" -I"C:\Program Files\MATLAB\R2019a\simulink\include" "c:\mca-master\mca.cpp" /FoC:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\mca.obj
CMDLINE100_1 : cl /c /Zp8 /GR /W3 /EHs /nologo /MD /O2 /Oy- /DNDEBUG /DDB_TEXT_GLBLSOURCE /DMSCC /DWIN32 /DWIN64 /DMATLAB_DEFAULT_RELEASE=R2017b /DUSE_MEX_CMD /D_CRT_SECURE_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0 /DMATLAB_MEX_FILE -I"c:\base-3.15.5\include" -I"c:\base-3.15.5\include\os\WIN32" -I"c:\base-3.15.5\include\compiler\msvc" -I"C:\Program Files\MATLAB\R2019a\extern\include" -I"C:\Program Files\MATLAB\R2019a\simulink\include" "c:\mca-master\MCAError.cpp" /FoC:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\MCAError.obj
CMDLINE100_2 : cl /c /Zp8 /GR /W3 /EHs /nologo /MD /O2 /Oy- /DNDEBUG /DDB_TEXT_GLBLSOURCE /DMSCC /DWIN32 /DWIN64 /DMATLAB_DEFAULT_RELEASE=R2017b /DUSE_MEX_CMD /D_CRT_SECURE_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0 /DMATLAB_MEX_FILE -I"c:\base-3.15.5\include" -I"c:\base-3.15.5\include\os\WIN32" -I"c:\base-3.15.5\include\compiler\msvc" -I"C:\Program Files\MATLAB\R2019a\extern\include" -I"C:\Program Files\MATLAB\R2019a\simulink\include" "c:\mca-master\Channel.cpp" /FoC:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\Channel.obj
CMDLINE100_3 : cl /c /Zp8 /GR /W3 /EHs /nologo /MD /O2 /Oy- /DNDEBUG /DDB_TEXT_GLBLSOURCE /DMSCC /DWIN32 /DWIN64 /DMATLAB_DEFAULT_RELEASE=R2017b /DUSE_MEX_CMD /D_CRT_SECURE_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0 /DMATLAB_MEX_FILE -I"c:\base-3.15.5\include" -I"c:\base-3.15.5\include\os\WIN32" -I"c:\base-3.15.5\include\compiler\msvc" -I"C:\Program Files\MATLAB\R2019a\extern\include" -I"C:\Program Files\MATLAB\R2019a\simulink\include" "C:\Program Files\MATLAB\R2019a\extern\version\cpp_mexapi_version.cpp" /FoC:\Users\HINKOK~1\AppData\Local\Temp\mex_1174891086813609_24416\cpp_mexapi_version.obj
Building with 'Microsoft Visual C++ 2017'.
mca.cpp
c:\mca-master\mca.cpp(206): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
c:\mca-master\mca.cpp(498): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
c:\mca-master\mca.cpp(499): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
c:\mca-master\mca.cpp(601): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
c:\mca-master\mca.cpp(644): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
c:\mca-master\mca.cpp(645): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
c:\mca-master\mca.cpp(679): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
MCAError.cpp
Channel.cpp
c:\mca-master\Channel.cpp(358): warning C4311: 'type cast': pointer truncation from 'epicsThreadId' to 'unsigned long'
c:\mca-master\Channel.cpp(358): warning C4302: 'type cast': truncation from 'epicsThreadId' to 'unsigned long'
c:\mca-master\Channel.cpp(365): warning C4311: 'type cast': pointer truncation from 'epicsThreadId' to 'unsigned long'
c:\mca-master\Channel.cpp(365): warning C4302: 'type cast': truncation from 'epicsThreadId' to 'unsigned long'
c:\mca-master\Channel.cpp(380): warning C4311: 'type cast': pointer truncation from 'epicsThreadId' to 'unsigned long'
c:\mca-master\Channel.cpp(380): warning C4302: 'type cast': truncation from 'epicsThreadId' to 'unsigned long'
c:\mca-master>
Thanks!
Hinko Kocevar
Beam Diagnostics Engineer
European Spallation Source ERIC
P.O Box 176, SE-221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, SE-224 84 Lund
, Sweden
Mobile: +46-721-79 22 58
Phone: +46-46-888 32 58
E-mail: [email protected]
Web: www.esss.se
- Re: Matlab MCA under windows 10 w/ VS 2017 Mark Rivers via Tech-talk
Re: RES: Pmac Slits Davis, Mark via Tech-talk
RE: RES: Pmac Slits Kivel Niko (PSI) via Tech-talk
<2019>
2025
2026
Re: convertRelease.pl checkRelease printing on stdout vs. stderr Hinko Kocevar via Tech-talk
<2019>
2025
2026
