1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: convertRelease.pl checkRelease printing on stdout vs. stderr
From: Hinko Kocevar via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Wed, 8 May 2019 18:16:05 +0000
Hi Andrew,
I’m using -jn, quite successfully, already.
Hinko
On 8 May 2019, at 19:27, Johnson, Andrew N. via Tech-talk <[email protected]> wrote:
We have some build rules that suppress additional status output when you use the “-s” switch, so that is definitely the recommend way to cut down on unnecessary output from the build.
We also support parallel builds using GNUmake's “-j n” flag, although some support modules may lack some of the necessary dependency information so I can't promise it works everywhere. When it works though this saves a lot of time on a machine that has multiple CPUs available. I do recommend providing a limit n unless your machine has lots of CPUs though, I can hang my personal 2*2 CPU Linux laptop with a “make -sj” because the build starves the OS processes of CPU long enough for something to not recover properly. My 12*2 CPU desktop machine at work handles it fine though. On Windows you should always provide a numeric limit as well, GNUmake's "too-busy" detector doesn't work properly there.
- Andrew
On 5/8/19 9:53 AM, Hinko Kocevar via Tech-talk wrote:
Thanks Mark, just changed to use the -s switch and it works as expected!
//hinko
Sent: Wednesday, May 8, 2019 2:35:47 PM
To: Hinko Kocevar
Cc: [email protected]
Hi Hinko,
The reason is that I use `make install >/dev/null` no to see all the cruft during compilation, but only errors/warnings.
The output of `convertRelease.pl checkRelease` is on stdout hence not seen in my case. I would like to see it though..
I am not disagreeing with you, but I think there is already another way to achieve what you want.
Rather than this:
do this:
make -s install
If you do that you will only see errors/warnings, but you will still see the messages from checkRelease.  I just tested that.
From: [email protected] <[email protected]> on behalf of Hinko Kocevar via Tech-talk <[email protected]>
Sent: Wednesday, May 8, 2019 7:19 AM
To: [email protected]
Subject: convertRelease.pl checkRelease printing on stdout vs. stderr
Would the messages from `convertRelease.pl checkRelease` be better off seen on the stderr, as opposed to stdout? I think that is what I'm seeing on Linux builds.
The reason is that I use `make install >/dev/null` no to see all the cruft during compilation, but only errors/warnings. The output of `convertRelease.pl checkRelease` is on stdout hence not seen in my case. I would like to see it though..
All the text between 'Definition of..' and 'make[2]: *** [checkRelease] Error 1' is on stdout:
make -C ./configure install
make[1]: Entering directory `/home/gitlab-runner/bde/R3.15.5/bpmioc-mebt/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/gitlab-runner/bde/R3.15.5/bpmioc-mebt/configure/O.linux-x86_64'
perl -CSD /opt/bde/R3.15.5/artifacts/epics-base-R3.15.5/bin/linux-x86_64/convertRelease.pl checkRelease
Definition of ADSUPPORT conflicts with IOCAPP support.
In this application a RELEASE file defines
        ADSUPPORT = /opt/bde/R3.15.5/artifacts/adsupport-master
but IOCAPP at /opt/bde/R3.15.5/artifacts/bpmapp-mebt defines
        ADSUPPORT = /opt/bde/R3.15.5/artifacts/adsupport-R1-4
Definition of ADSIS8300 conflicts with IOCAPP support.
        ADSIS8300 = /opt/bde/R3.15.5/artifacts/adsis8300-bpm
        ADSIS8300 = /opt/bde/R3.15.5/artifacts/adsis8300-master
Definition of ASYN conflicts with IOCAPP support.
        ASYN = /opt/bde/R3.15.5/artifacts/asyn-master
        ASYN = /opt/bde/R3.15.5/artifacts/asyn-R4-33
Definition of ADSUPPORT conflicts with BPMAPP support.
but BPMAPP at /opt/bde/R3.15.5/artifacts/bpmapp-mebt defines
Definition of ADSIS8300 conflicts with BPMAPP support.
Definition of ASYN conflicts with BPMAPP support.
make[2]: Leaving directory `/home/gitlab-runner/bde/R3.15.5/bpmioc-mebt/configure/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/gitlab-runner/bde/R3.15.5/bpmioc-mebt/configure'
make: *** [configure.install] Error 2
Hinko Kocevar
Beam Diagnostics Engineer
European Spallation Source ERIC
P.O Box 176, SE-221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, SE-224 84 Lund
, Sweden
Mobile: +46-721-79 22 58
Phone:  +46-46-888 32 58
E-mail: [email protected]
Web:    www.esss.se<http://www.esss.se>
Complexity comes for free, Simplicity you have to work for.
convertRelease.pl checkRelease printing on stdout vs. stderr Hinko Kocevar via Tech-talk
Re: convertRelease.pl checkRelease printing on stdout vs. stderr Mark Rivers via Tech-talk
Re: convertRelease.pl checkRelease printing on stdout vs. stderr Hinko Kocevar via Tech-talk
Re: convertRelease.pl checkRelease printing on stdout vs. stderr Johnson, Andrew N. via Tech-talk
Prev: Re: convertRelease.pl checkRelease printing on stdout vs. stderr Johnson, Andrew N. via Tech-talk
Next: Re: RES: Pmac Slits Davis, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Matlab MCA under windows 10 w/ VS 2017 Hinko Kocevar via Tech-talk
ANJ, 09 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
