Hi Xing,
You have the latest CentOS 7 up-to-date version.
This bug is related with nautils and other Qt objects within your
GUI environment. You could wait for their upcoming patch, because of
this patch https://bugzilla.redhat.com/show_bug.cgi?id=1594177
If you want to do some minimal action to work around this issue, I
recommend to install "Mate Desktop" instead of Qt or Gnome.
sudo yum install epel-release -y
sudo yum groupinstall "Mate Desktop" -y
sudo reboot
In the login terminal, you can see the small option symbol below the
login window (*), you can switch from gnome classic or 3 to Mate.
Please try to do this first, and let me know. In case, this quick
solution doesn't work with your environment because of your
configuration. I hope your system has the default and native repository
configuration.
HTH,
Han
On 5/13/19 4:26 PM, 网易邮件中心 via Tech-talk wrote:
Hi all,
I have a question about Linux OS.
My epics shell always shutdown itself in this computer, so the
epics ioc could not run long time.
I do not quite know how the OS shutdown. I just know the ioc was
shut down. I means that I don't know what happened.
I checked the log and found these information bellow.
I am not good at the linux OS, so I am here ask for help.
Could someone tell me how to fix it.
Li xing
My OS informaion
root@localhost log]# cat /proc/version
Linux version 3.10.0-957.12.1.el7.x86_64
([email protected]) (gcc version 4.8.5 20150623 (Red
Hat 4.8.5-36) (GCC) ) #1 SMP Mon Apr 29 14:59:59 UTC 2019
[root@localhost log]# lsb_release -a
LSB Version:
:core-4.1-amd64:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch
Distributor ID: CentOS
Description: CentOS Linux release 7.6.1810 (Core)
Release: 7.6.1810
Part of my log(message):
And I found someone report the same question in the
https://bugs.centos.org/view.php?id=15900
<https://bugs.centos.org/view.php?id=15900.>
May 13 20:03:39 localhost journal: STACK_OP_ADD: window 0x3000001
already in stack
May 13 20:03:40 localhost : QSGContext::initialize: depth buffer support
missing, expect rendering errors
May 13 20:03:40 localhost : QSGContext::initialize: stencil buffer
support missing, expect rendering errors
May 13 20:03:40 localhost journal: JS WARNING:
[resource:///org/gnome/shell/ui/keyboard.js 553]: reference to undefined
property "_rect"
May 13 20:03:40 localhost journal: JS ERROR: Exception in callback for
signal: position-changed: TypeError: this._rect is
undefined#012getCurrentRect@resource:///org/gnome/shell/ui/keyboard.js:553:22#012wrapper@resource:///org/gnome/gjs/modules/_legacy.js:82:22#012_onFocusPositionChanged@resource:///org/gnome/shell/ui/keyboard.js:635:20#012wrapper@resource:///org/gnome/gjs/modules/_legacy.js:82:22#012_emit@resource:///org/gnome/gjs/modules/signals.js:128:27#012_setCurrentWindow/this._currentWindowPositionId<@resource:///org/gnome/shell/ui/keyboard.js:534:21
May 13 20:03:40 localhost journal: g_simple_action_set_enabled:
assertion 'G_IS_SIMPLE_ACTION (simple)' failed
May 13 20:03:40 localhost gnome-shell: GNOME Shell started at Mon May 13
2019 20:03:36 GMT+0800 (CST)
May 13 20:03:40 localhost dracut: *** Installing kernel module
dependencies and firmware done ***
May 13 20:03:40 localhost dracut: *** Resolving executable dependencies ***
May 13 20:03:40 localhost : QSystemTrayIcon::setVisible: No Icon set
May 13 20:03:41 localhost journal: g_simple_action_set_enabled:
May 13 20:03:41 localhost journal: Exiting
May 13 20:03:41 localhost dracut: *** Resolving executable dependencies
done***
- OS question 网易邮件中心 via Tech-talk
Re: OS question Mark Rivers via Tech-talk
Re: OS question Ivashkevych, Oksana via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
