I should have been more specific. This seem to be isolated to newest version 16.04 of the Visual Studio, and thanks for all the responses.
Visual Studio Community Edition version 16.04
EPICS Base: 7.0.2.2
make 4.2.1
Kaz
-----Original Message-----
Sent: Friday, 17 May 2019 3:34 PM
To: Gofron, Kazimierz <[email protected]>
Cc: [email protected]; Zimoch Dirk (PSI) <[email protected]>
Subject: Re: asyn 4-35 does not compile on Windows 10 (VS 2019)
It compiles fine on VS2015 (and VS2017 I believe)
Sent from my iPhone
On May 17, 2019, at 3:15 PM, Gofron, Kazimierz <[email protected]<mailto:[email protected]>> wrote:
I am having problems compiling asyn 4-35 (and current version of master) on Windows 10 with Visual Studio 2019 Community Edition. Problem is specific to windows since asyn-4-35 compiles on debian 7/8/9 and ubuntu 18.
C:\epics\support\asyn>make
make[1]: Entering directory 'C:/epics/support/asyn/asyn'
perl -CSD C:/epics/base/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. \
T_A=windows-x64 install
make[2]: Entering directory 'C:/epics/support/asyn/asyn/O.windows-x64'
cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/epics/support/ipac/include -IC:/epics/support/seq/include -IC:/epics/base/include/compiler/msvc -IC:/epics/base/include/os/WIN32 -IC:/epics/base/include -c ../../asyn/drvAsynSerial/drvAsynIPPort.c
drvAsynIPPort.c
c:\epics\support\asyn\asyn\drvasynserial\drvasynipport.c(462) : warning C4267: 'function' : conversion from 'size_t' to 'int', possible loss of data .....
cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/epics/support/ipac/include -IC:/epics/support/seq/include -IC:/epics/base/include/compiler/msvc -IC:/epics/base/include/os/WIN32 -IC:/epics/base/include -c ../../asyn/miscellaneous/asynInterposeDelay.c
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(216) : error C2059: syntax error : '{'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(220) : error C2059: syntax error : '}'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(229) : fatal error C1903: unable to recover from previous error(s); stopping compilation
make[2]: *** [C:/epics/base/configure/RULES_BUILD:235: asynInterposeDelay.obj] Error 2
make[2]: Leaving directory 'C:/epics/support/asyn/asyn/O.windows-x64'
make[1]: *** [C:/epics/base/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[1]: Leaving directory 'C:/epics/support/asyn/asyn'
make: *** [C:/epics/base/configure/RULES_DIRS:84: asyn.install] Error 2 ==========================================================================================
There is a similar error in asyninterposeecho.c, when compiling with -sj> make -sj
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(190) : error C2059: syntax error : '{'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(193) : error C2059: syntax error : '}'
ParamValWrongType.cpp
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(202) : fatal error C1903: unable to recover from previous error(s); stopping compilation
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(229) : fatal error C1903: unable to recover from previous error(s); stopping compilation paramVal.cpp
make[2]: *** [C:/epics/base/configure/RULES_BUILD:234: asynInterposeEcho.obj] Error 2
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [C:/epics/base/configure/RULES_BUILD:234: asynInterposeDelay.obj] Error 2 ParamValValueNotChanged.cpp asynPortDriver.cpp asynPortClient.cpp devAsynOctet.c
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(326) : warning C4267: '=' : conversion from 'size_t' to 'epicsUInt32', possible loss of data
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(746) : warning C4267: '=' : conversion from 'size_t' to 'epicsUInt32', possible loss of data
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(751) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(136) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(144) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(157) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(796) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
The source lines indicate the Visual Studio does not interpret 2nd set of "{"
/* register asynInterposeEcho*/
static const iocshFuncDef asynInterposeEchoFuncDef =
{"asynInterposeEcho", 2, (const iocshArg *[]) {
&(iocshArg) { "portName", iocshArgString },
&(iocshArg) { "addr", iocshArgInt },
/* register asynInterposeDelay*/
static const iocshFuncDef asynInterposeDelayFuncDef =
{"asynInterposeDelay", 3, (const iocshArg *[]) {
&(iocshArg) { "delay(sec)", iocshArgDouble },
Cheers,
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]<mailto:[email protected]>
(w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
- asyn 4-35 does not compile on Windows 10 (VS 2019) Gofron, Kazimierz via Tech-talk
- Re: asyn 4-35 does not compile on Windows 10 (VS 2019) Mark Rivers via Tech-talk
RE: asyn 4-35 does not compile on Windows 10 (VS 2019) Gofron, Kazimierz via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
