Subject: |
question about pvAccess/pvData, pvPut |
Heinz Junkes via Tech-talk <[email protected]> |
To: |
tech-talk <[email protected]> |
Date: |
Wed, 22 May 2019 18:19:16 +0200 |
I have a data source (VMEbus-digitizer, RTEMS, EPICS 7) that sends
with pvaPut Dataframes ( ~ 2 MByte ) about 1000 times/s to a server which holds
a Pv.
PV-Structure:
structure
structure value
double[] column0
double[] column1
double[] column2
double[] column3
string[] labels
string[] units
string descriptor
long counter
structure[] attribute
structure
string name
any value
string descriptor
int sourceType
int source
double[] digitizerTimeStamp
structure timeStamp
long secondsPastEpoch
int nanoseconds
int userTag
structure alarm
int severity
int status
string message
What is the proposed way to guarantee that the transmitter will get rid of its data within 1ms, regardless of how many monitors are attached to the PV?
And if possible also independent of the load of the server. Can this even be guaranteed with pvAccess?
Are there such things like caches, pipelines etc.? Or do you have to implement it yourself?
Danke,
HeinzAttachment:
smime.p7s
Description: S/MIME cryptographic signature
- Re: question about pvAccess/pvData, pvPut Heinz Junkes via Tech-talk
scanServiceExample Marty Kraimer via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
