1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: question about pvAccess/pvData, pvPut
From: Heinz Junkes via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Wed, 22 May 2019 19:29:05 +0200
Excuse me, there's an "0" too much slipped in while typing …
~ 2 MByte  100 times/s.
> On 22. May 2019, at 18:19, Heinz Junkes via Tech-talk <[email protected]> wrote:
> I have a data source (VMEbus-digitizer, RTEMS, EPICS 7) that sends
> with pvaPut Dataframes ( ~ 2 MByte )  about 1000 times/s  to a server which holds
> a Pv.
> PV-Structure:
> structure
>    structure value
>        double[] column0
>        double[] column1
>        double[] column2
>        double[] column3
>    string[] labels
>    string[] units
>    string descriptor
>    long counter
>    structure[] attribute
>        structure
>            string name
>            any value
>            string descriptor
>            int sourceType
>            int source
>    double[] digitizerTimeStamp
>    structure timeStamp
>        long secondsPastEpoch
>        int nanoseconds
>        int userTag
>    structure alarm
>        int severity
>        int status
>        string message
> What is the proposed way to guarantee that the transmitter will get rid of its data within 1ms, regardless of how many monitors are attached to the PV?
> And if possible also independent of the load of the server. Can this even be guaranteed with pvAccess?
> Are there such things like caches, pipelines etc.? Or do you have to implement it yourself?
> Danke,
> Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
question about pvAccess/pvData, pvPut Heinz Junkes via Tech-talk
Prev: question about pvAccess/pvData, pvPut Heinz Junkes via Tech-talk
Next: registerRecordDeviceDriver.obj unresolved external symbols Thomas, Patrick via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 22 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
