Hi Joe,
On 5/24/19 4:16 PM, Sullivan, Joseph via Tech-talk wrote:
The following warning messages are appearing periodically (~2hrs) on all the EPICs IOC's (VxWorks and Linux -
base-3.14.12.3) on a beamline here at the APS - (base-3.14.12.3).
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 169.254.0.2:3956 ignored
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 169.254.132.146:3956 ignored
IP addresses in the 169.254 range are self-assigned by a computer that cannot get an address from a DHCP server. You should have IT track down which network port(s) are using these addresses and get those machines configured properly (or have them disconnected).
Eventually the CAS-Event processes fail (after a day or so). A reboot brings everything back and the sequence starts over.
That is unfortunate, we would like IOCs to be immune to bad packets. If you can get a packet capture of the broadcast packets going to port 5064 on this network (before the rogue client gets killed) it would let us try to prevent this particular payload from
crashing the IOCs.
This happened after the IOCs where brought up after a shutdown period.
Is this a network issue (someone on the CA ports that should not be) or should I look at the CA Clients (medm)?
I don't think these messages would be caused by a real CA client, even one that doesn't have a proper IP address. You need to get the network police down to that beamline to find the rogue machine(s). It's a pity it's now after 5pm on a holiday weekend; Mary
is still here though.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: UDP Warnings (VME and Linux) - Subnet wide Sullivan, Joseph via Tech-talk
- UDP Warnings (VME and Linux) - Subnet wide Sullivan, Joseph via Tech-talk
Re: UDP Warnings (VME and Linux) - Subnet wide Mark Rivers via Tech-talk
Stream module git link broken? Gofron, Kazimierz via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 10 Jun 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
