1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: New releases of areaDetector drivers ADSimDetector, ADPerkinElmer, and ADSpinnaker
Date: Wed, 29 May 2019 23:13:47 +0000
Folks,
New releases of the following areaDetector modules are now available.
ADSimDetector
R2-9 (May 29, 2019)
* Requires asyn R4-35 because of changes to the asynPortClient class used in simDetectorNoIOC (see below).
* Changes in the simulation modes and parameters to improve utility and performance.
  * The Noise parameter now applies to all simulation modes, not just to Peaks mode.
  * The Noise computation only calls rand() when the image is reset, i.e. the data type,
    dimensions, etc. are changed.  In normal cases it just adds the precomputed noise
    to each pixel starting at a random pixel.  This means the noise spatial pattern is the same
    in each successive image, but starting at a different pixel.  This makes it look quite random
    while being very fast.
  * A new Offset parameter now applies to all simulation modes.
  * The sineNoise and sineOffset parameters were removed, replaced by Noise and Offset.
  * PeakVariation was changed from longout record to ao record so it is not constrained to be an integer.
  * Removed the dependence of the image data on the AcquireTime.  This was confusing and meant the data
    changed significantly when the AcquireTime changed.
  * Improved performance of Peaks mode by more than 10X.  Previously it computed the Gaussian peak profile
    for each peak in the image.  Now it only does the Gausssian calculation once into a scratch buffer
    and then copies that peak multiple times into the output image at different locations.
  * A new simulation mode Offset&Noise was added.  This mode only does offset and noise, and
    is the fastest simulation mode.  It can generate >700 frames/s using 1024x1024 images and asynFloat64
    data type, which is >5GB/s.  In asynUInt8 mode it can generate >3000 frames/s which is >3GB/s.
* simDetectorNoIOC
  * This directory contains a pure C++ application that instantiates a simDetector, a statistics plugin,
    and an HDF5 file plugin outside the context of an EPICS IOC.
    It is intended in part to demonstrate that areaDetector drivers and plugins can be used with other
    control systems such as Tango.
  * This application has been considerably improved and simplified by using the new versions of the
    asynPortClient and asynParamClient classes in asyn R4-35.
* iocHDF5Test
  * Fixed the startup scripts.
ADPerkinElmer
R2-9 (29-May-2019)
* Fixed error reading bad pixel file.  There were 2 problems:
  - The structures defined in Acq.h were not declared to be packed.  This caused the structures to be
    read incorrectly from the bad pixel file. In particular the image dimensions were read wrong.
    Added #pragma pack(1) when including Acq.h so these structures are packed.
  - Because of the previous problem the driver was deliberately using the wrong fields in the structure to determine
    the dimensions of the image array in the file (ULY, BRX, rather than BRX, BRY).
    If a compiler did do structure packing then the driver would crash in loadPixelCorrectionFile
    because the wrong structure members were being used.
* Fixed error in loadGainFile().  It was using the PE_CorrectionsDirectory instead of PE_GainFile.
ADSpinnaker  (new driver for Spinnaker SDK for FLIR/Point Grey cameras)
R1-0 (May 29, 2019)
* Initial release
Prev: Re: Receiving duplicate monitor values using CA PV Gateway William Layne via Tech-talk
Next: RE: devSup driver development differences between base 3.14 and 3.15 Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: Receiving duplicate monitor values using CA PV Gateway Layne (US), William C via Tech-talk
Next: How to share asyn's queue thread among ports? Klemen Vodopivec via Tech-talk
ANJ, 03 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
