Thanks, Mark,
I will roll a fix into the next release.
Sent: 29 May 2019 19:04:39
To: [email protected]; Knap, Giles (DLSLtd,RAL,LSCI)
Subject: pmac driver bug
To Giles and other interested parties,
I found another bug in the pmac driver (version 2-4-10):
The section of code in the pmacAxis::home() function that is
conditionally compiled based on the macro REMOVE_LIMITS_ON_HOME does not
check for the PMAC_CID_POWER CID value, so when using a Power Brick
controller it simply logs an error (if enabled) and exits.
The older version of the driver I was using had the definition of the
PMAC_CID_POWER macro commented out, so the offending section of code was
not included and it would just send the home command regardless of what
type of controller you have.
For now, I commented this macro out in the newer version to get the same
behavior as the older one.
Mark Davis
NSCL/FRIB
Control Systems Software Engineer
[email protected]
- Re: pmac driver bug Davis, Mark via Tech-talk
- pmac driver bug Davis, Mark via Tech-talk
RE: devSup driver development differences between base 3.14 and 3.15 Abdalla Ahmad via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
