1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Camonitor with client dictated update rate
From: Emanuele Laface via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Mon, 3 Jun 2019 19:49:20 +0000
Thanks, I will try this solution as soon as possible.
e.
On 3 Jun 2019, at 19:47, Johnson, Andrew N. <[email protected]> wrote:
Hi Emanuele,
On 6/2/19 4:25 PM, Emanuele Laface via Tech-talk wrote:
I have this scenario: N PVs of waveforms (arrays) of 10^5 data in each PV.
The IOc runs at 14 Hz, it means that if I subscribe in monitor mode I will be updated 14 times per second with N x 10^5 numbers.
Now I have an interface that I want to update just once per second with the content of these waveforms.
If I am in monitor, I can easily get the value once per second but my python script will anyway use the bandwidth and the cpu to process at 14 Hz because the threads of the monitoring will be updated at that frequency.
If I use caget once per second I need to deal with all the timeouts that can occur if some pv is down, disconnected, unreachable etc.
I haven’t find a reliable way to get the data once per second in a full asynchronous mode but without rejecting the data that anyway occupy bandwidth and cpu.
So from your description you really want/need the filtering to happen at the server. The existing solution for this is to add an additional record to the IOC for each waveform that you want to see at 1 Hz. The "slow data" record would have SCAN="1 second" and its INP link would be a DB link pointing to the equivalent "fast data" waveform record. Then once every second the "slow" record reads the current array from the "fast" record and publishes it from its own VAL field.
However I just converted the existing "sync" server-side filter into a fairly simplistic "dec" (decimate) filter which allows a client to request only one in every N monitor updates from a channel. Here I'm monitoring a 1Hz counter anj:count but also asking for a decimated view of that counter that gives me only one in three of the updates:
tux% camonitor anj:count 'anj:count.{"dec":{"n":3}}'
anj:count                      2019-06-03 12:26:26.719940 16
anj:count.{"dec":{"n":3}}      2019-06-03 12:26:26.719940 16
anj:count                      2019-06-03 12:26:27.719992 17
anj:count                      2019-06-03 12:26:28.719933 18
anj:count                      2019-06-03 12:26:29.719946 19
anj:count.{"dec":{"n":3}}      2019-06-03 12:26:29.719946 19
anj:count                      2019-06-03 12:26:30.719933 20
anj:count                      2019-06-03 12:26:31.719952 21
My demonstration shows a scalar value but it will work for any array field too. You can add this filter directly to any 3.15 or later IOC: Just build the attached source file into the IOC and add the registrar entry below to a DBD file that it also loads:
registrar(decInitialize)
If this filter works for you I will add it to the next 3.15 release of Base.
- Andrew
Complexity comes for free, Simplicity you have to work for.
<decimate.c>
Re: Camonitor with client dictated update rate Hinko Kocevar via Tech-talk
Re: Camonitor with client dictated update rate William Layne via Tech-talk
Re: Camonitor with client dictated update rate Matt Newville via Tech-talk
Re: Camonitor with client dictated update rate Emanuele Laface via Tech-talk
Re: Camonitor with client dictated update rate Johnson, Andrew N. via Tech-talk
Prev: Re: Camonitor with client dictated update rate Johnson, Andrew N. via Tech-talk
Next: Re: Camonitor with client dictated update rate Hinko Kocevar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 03 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
