1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Animatics SmartMotor setup
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Mark Davis <[email protected]>, "Davis, Mark" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 18 Jun 2019 13:44:37 +0200
Hej Mark,
you need 2 asyn ports, one for the motorRecord to
talk to your "Animatics SmartMotor" asynMotorDriver.
The second one to let the "Animatics SmartMotor" asynMotorDriver
talk to the real hardware.
We call them "MCU1" and "MC_CPU1", better suggestions are welcome.
A simplified setup is here:
## The db file:
record(motor,"$(PREFIX)$(MOTOR_NAME)")
	field(DESC,"$(DESC)")
	field(DTYP,"asynMotor")
	field(OUT,"@asyn($(MOTOR_PORT),$(AXIS_NO))")
##st.cmd
epicsEnvSet("ASYN_PORT",     "MC_CPU1")
epicsEnvSet("MOTOR_NAME",    "IOC:m1")
epicsEnvSet("MOTOR_PORT",    "MCU1")
epicsEnvSet("AXIS_NO",       "1")
drvAsynIPPortConfigure("$(ASYN_PORT)","$(IPADDR):$(IPPORT)",0,0,0)
EthercatMCCreateController("$(MOTOR_PORT)", "$(ASYN_PORT)", "$(NUMAXES)", "200", "1000")
EthercatMCCreateAxis("$(MOTOR_PORT)", "$(AXIS_NO)",)
I hope that hopes a little bit.
/Torsten
On 18/06/19 13:11, Davis, Mark via Tech-talk wrote:
Can anyone provide an example of how to setup and use an Animatics SmartMotor?
From what I could figure out looking at the code, I expect it is something along these lines:
# For a connection via a Moxa Ethernet-to-serial adapter:
drvAsynIPPortConfigure("TapeStation", "192.168.137.99:4001")
# SmartMotorSetup(maxCtlrCount, pollRate)
SmartMotorSetup(1, 5)
# SmartMotorConfig(cardNum, "asynPortName")
SmartMotorConfig(0, "TapeStation")
And then the motor record would look something like this:
record(motor, "MyMotor")
   field(DTYP, "SmartMotor")
   field(OUT,  "@0 TapeStation ????")
Is that even close?  The one I am most unsure of is what to use for the OUT value in the motor record.
Mark Davis
NSCL/FRIB
Re: Animatics SmartMotor setup Davis, Mark via Tech-talk
Prev: Animatics SmartMotor setup Davis, Mark via Tech-talk
Next: Re: PVA Client in python Siniša Veseli via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: FW: Animatics SmartMotor setup Mark Rivers via Tech-talk
ANJ, 18 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
