1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: FW: Animatics SmartMotor setup
Date: Tue, 18 Jun 2019 14:05:56 +0000
Forgot to CC tech-talk.
-----Original Message-----
Sent: Tuesday, June 18, 2019 9:05 AM
To: 'Torsten Bögershausen' <[email protected]>; Mark Davis <[email protected]>; Davis, Mark <[email protected]>
Subject: RE: Animatics SmartMotor setup
Hi Mark,
What Torsten says is true for Model 2 and Model 3 motor drivers.  However the SmartMotorSrc driver is an old Model 1 driver, so the driver is not derived from asynPortDriver and it only has the single asyn port to the underlying drvAsynIPPort.
The OUT field syntax for Model 1 drivers is:
        field(OUT,"#C$(C) S$(S) @")
where $(C) is the card number, and $(S) is the signal number.  So for the first axis on the first controller it would be
     field(OUT,  "#C0 S0 @")
From: [email protected] <[email protected]> On Behalf Of Torsten Bögershausen via Tech-talk
Sent: Tuesday, June 18, 2019 6:45 AM
To: Mark Davis <[email protected]>; Davis, Mark <[email protected]>; [email protected]
Subject: Re: Animatics SmartMotor setup
Hej Mark,
you need 2 asyn ports, one for the motorRecord to talk to your "Animatics SmartMotor" asynMotorDriver.
The second one to let the "Animatics SmartMotor" asynMotorDriver talk to the real hardware.
We call them "MCU1" and "MC_CPU1", better suggestions are welcome.
A simplified setup is here:
## The db file:
record(motor,"$(PREFIX)$(MOTOR_NAME)")
	field(DESC,"$(DESC)")
	field(DTYP,"asynMotor")
	field(OUT,"@asyn($(MOTOR_PORT),$(AXIS_NO))")
##st.cmd
epicsEnvSet("ASYN_PORT",     "MC_CPU1")
epicsEnvSet("MOTOR_NAME",    "IOC:m1")
epicsEnvSet("MOTOR_PORT",    "MCU1")
epicsEnvSet("AXIS_NO",       "1")
drvAsynIPPortConfigure("$(ASYN_PORT)","$(IPADDR):$(IPPORT)",0,0,0)
EthercatMCCreateController("$(MOTOR_PORT)", "$(ASYN_PORT)", "$(NUMAXES)", "200", "1000")
EthercatMCCreateAxis("$(MOTOR_PORT)", "$(AXIS_NO)",)
I hope that hopes a little bit.
/Torsten
On 18/06/19 13:11, Davis, Mark via Tech-talk wrote:
> Can anyone provide an example of how to setup and use an Animatics SmartMotor?
>  From what I could figure out looking at the code, I expect it is
> something along these lines:
> # For a connection via a Moxa Ethernet-to-serial adapter:
> drvAsynIPPortConfigure("TapeStation", "192.168.137.99:4001")
> # SmartMotorSetup(maxCtlrCount, pollRate) SmartMotorSetup(1, 5)
> # SmartMotorConfig(cardNum, "asynPortName") SmartMotorConfig(0,
> "TapeStation")
> And then the motor record would look something like this:
> record(motor, "MyMotor")
>    field(DTYP, "SmartMotor")
>    field(OUT,  "@0 TapeStation ????")
> Is that even close?  The one I am most unsure of is what to use for
> the OUT value in the motor record.
> Mark Davis
> NSCL/FRIB
Animatics SmartMotor setup Davis, Mark via Tech-talk
Re: Animatics SmartMotor setup Torsten Bögershausen via Tech-talk
Prev: Re: PVA Client in python Florian Feldbauer via Tech-talk
Next: Re: Animatics SmartMotor setup Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Animatics SmartMotor setup Torsten Bögershausen via Tech-talk
ANJ, 18 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
