Hi Matt,
Thanks for the reply. The status message was cut off in my display, so I missed the "(press Stop when done)". That does indicate the expected behavior is what I'm seeing, though not what I guessed based on the Internal Series behavior. I appreciate the clarification!
All the best.
- Jesse
---- Jesse Hopkins, PhDBeamline Scientist BioCAT, Sector 18 Advanced Photon Source
On Wed, Jun 26, 2019 at 10:08 AM Jesse Hopkins via Tech-talk < [email protected]> wrote: Hi,
We have an Eiger X 500K. I'm using AreaDetector to control it, and encountering a strange issue with the External Series trigger mode. I set the trigger mode to external series, and 'Start' collection. If I then send an external trigger, the series collects as expected. I can watch NumImagesCounter_RBV increment, and it reports the right number of images collected. However, after all the images are collected, Acquire stays 'Collecting'. In order to take another series I have to first click the 'Stop' button. Additionally, the StatusMessage_RBV stays as 'Waiting for external trigger' until I click the 'Stop' button.
This is in contrast to the Internal Series behavior, where at the end of a series Acquire goes to 'Done' as I would expect.
Yes, we see the same behavior for our Eiger 500K in either External Enable and External Series modes: we have to explicitly stop the detector. To be clear, if we set NumTriggers to 10 and send it 20 pulses, it will count up to 10 triggers. Any file writing or processing plugin will only get 10 frames. But the detector will still be in Acquiring Mode and (using ADCore 3.5.0) the StatusMesssage says Waiting for external triggers (press Stop when done)
But like you see, we have to explicitly stop the detector to be able to then restart it.
--Matt Newville
- Problem with AreaDetector and Eiger External Series? Jesse Hopkins via Tech-talk
- Re: Problem with AreaDetector and Eiger External Series? Matt Newville via Tech-talk
Re: Problem with AreaDetector and Eiger External Series? Mark Rivers via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 26 Jun 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
