1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with AreaDetector and Eiger External Series?
To: Matt Newville <[email protected]>
Date: Wed, 26 Jun 2019 17:28:44 +0000
Hi Jesse,
This is a known problem. I believe it is a bug in the Dectris server. However, we can probably work around the problem in the ADEiger driver. Can you create an issue for it on Github?
Sent from my iPhone
On Jun 26, 2019, at 12:20 PM, Matt Newville via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi Jesse,
On Wed, Jun 26, 2019 at 10:08 AM Jesse Hopkins via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
We have an Eiger X 500K. I'm using AreaDetector to control it, and encountering a strange issue with the External Series trigger mode. I set the trigger mode to external series, and 'Start' collection. If I then send an external trigger, the series collects as expected. I can watch NumImagesCounter_RBV increment, and it reports the right number of images collected. However, after all the images are collected, Acquire stays 'Collecting'. In order to take another series I have to first click the 'Stop' button. Additionally, the StatusMessage_RBV stays as 'Waiting for external trigger' until I click the 'Stop' button.
This is in contrast to the Internal Series behavior, where at the end of a series Acquire goes to 'Done' as I would expect.
Yes, we see the same behavior for our Eiger 500K in either External Enable and External Series modes: we have to explicitly stop the detector.   To be clear, if we set NumTriggers to 10 and send it 20 pulses, it will count up to 10 triggers.  Any file writing or processing plugin will only get 10 frames.  But the detector will still be in Acquiring Mode and (using ADCore 3.5.0) the StatusMesssage says
     Waiting for external triggers (press Stop when done)
But like you see, we have to explicitly stop the detector to be able to then restart it.
--Matt Newville
Re: Problem with AreaDetector and Eiger External Series? Jesse Hopkins via Tech-talk
Re: Problem with AreaDetector and Eiger External Series? Matt Newville via Tech-talk
Prev: Re: Problem with AreaDetector and Eiger External Series? Jesse Hopkins via Tech-talk
Next: Re: Problem with AreaDetector and Eiger External Series? Bruno Martins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problem with AreaDetector and Eiger External Series? Jesse Hopkins via Tech-talk
ANJ, 26 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
