1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How is 'exit()' different for the IOC shell?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Wed, 26 Jun 2019 21:51:21 +0000
Hello Kay,
On 6/26/19 3:48 PM, Kasemir, Kay via Tech-talk wrote:
To test a client for an IOC that keeps restarting, I tried this:
  while true
  do
     softIoc brief.cmd
  done
 with brief.cmd like this:
  dbLoadDatabase("/path/to/softIoc.dbd")
  dbLoadRecords("demo.db")
  iocInit()
  epicsThreadSleep(10)
  date()
  exit()
The IOC starts, after 10 seconds the date is printed, but instead of then exiting, I get the "epics>" prompt.
Same when I don't include "exit()".
Why does exit() in the startup script not exit?
It exits the iocShell instance that is taking commands from your startup script, but doesn't exit the IOC process. We normally start a second iocShell instance to accept commands from stdin. If you don't want that second interactive iocShell instance to be run, pass the option '-S' to the softIoc executable. However doing that won't actually cause the IOC to exit, it just hangs up the main thread and allows the IOC to continue to run. An IOC in this state cannot be stopped using Control-C either, you have to use kill -9 for it to die, or have it commit suicide as follows:
The softIoc can load an exit subroutine (similar to the SYSRESET PV that Mike mentioned but with a built in subroutine) which will cause the IOC to exit when you process it (which you can do through CA). You use the option '-x <prefix>' to load a subrecord called '<prefix>:exit', or you can load your own subroutine record with SNAM=exit (see your Base/db/softIocExit.db file for details). You can control the exit status of the IOC process by setting <prefix>:exit.A to a non-zero value for it to return EXIT_FAILURE.
BTW if all you want is to load one or more databases with macros and run iocInit you don't need a startup script at all, you can just do this:
  while true
  do
     softIoc -m VAR=value -d demo.db -x testIoc -S
  done
Your demo.db would have to process the exit PV itself after 10 seconds for the IOC to quit though. You can have as many '-m ... -d ...' options on the command-line as you like to set macro values and load databases. It can even load an access security control file too (-a filepath).
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
How is 'exit()' different for the IOC shell? Kasemir, Kay via Tech-talk
Prev: Re: How is 'exit()' different for the IOC shell? Zelazny, Michael Stanley via Tech-talk
Next: Re: How is 'exit()' different for the IOC shell? Konrad, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
