1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Accessing Elements of a Waveform Record
From: "Steiner, Mathias via Tech-talk" <[email protected]>
To: Christopher Herrmann <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 2 Jul 2019 21:46:51 +0000
Chris,
If I were doing this and wanted to be flexible, I'd use an aSub record and use the waveform as well as the indeces as input values.
cheers -mathias
From: [email protected] [[email protected]] on behalf of Christopher Herrmann via Tech-talk [[email protected]]
Sent: Tuesday, July 2, 2019 4:43 PM
To: [email protected]
Subject: Accessing Elements of a Waveform Record
Hello,
Currently, I have a waveform record that holds 10 different values.
I was wondering if there was any way to reference an individual element
in that waveform record. My best solution so far is to use the "aCalcOut"
record and have it process, then output, a single hard coded value.
Something like this for the "calc" field:
field(CALC, "AA[0,0]") or field(CALC, "AA[1,1]")
While this is fine for a few elements, I may need to be able to access up
to 30 different values in a single waveform record individually.
Are there any clever or streamline ways to go about this?
Thank you,
~ Chris
Prev: Re: Fwd: cross-compiling (kind of) with Buildroot Johnson, Andrew N. via Tech-talk
Next: Re: [EXTERNAL] Beckhoff BK9000 support survey Wallace, Alex via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Accessing Elements of a Waveform Record Johnson, Andrew N. via Tech-talk
Next: BNL Job Opening in NSLS-II Controls Anton Derbenev via Tech-talk
ANJ, 02 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
